Ok, I just bought a ton of Injector O-rings. I ordered online, so there was no other option than to order in bulk lol. This is confirmed to fit the SL4 series of RC engineering injectors. If there are any other injectors with the same dimension such as the PL4, then it should work as well.
You get the 24 o-rings in the second photo. Selling for $15 shipped for the rings needed for 6 injectors on the 2JZ-GE motor.
It's pretty expensive for these type of rings at autozone. Actually, you have to buy 6 separate assorted boxes each costing about $8. Keep in mind, these are Viton rings...not your normal run of the mill rubber ones.
These are made out of Viton material so they can withstand harsh chemicals and high temperatures.
Eh, I'm not quite sure if these are the correct O-rings you need. Do you have the RC engineering injectors or what? Provide a model number of your injectors just to make sure.
Jeff, I know you still probably have a few of these left over. I need six of the O-rings that you have double up near the top where it attaches to the rail.
