FS: SOCAL GS3 Veilside hood, imported aero kit PICK UP ONLY
yes im sure about that 100% because i have put the stock grill on this hood and it worked fine. to double check i also called up veilside to confirm and they said that it can use ONLY the OEM grill or the veilside grill.
i will take better pics of the grill mounting points, and also with the stock grill attached on the hood.
yep, you can use stock grills or the likes of them. i dont have any experiences with the other types of grills so i cant say if it will fit or not. but i know for sure that the stock and veilside one will fit in there.
OKay, from previous experience
The Veilside hood only takes the OEM Grille and the Veilside Grille no modifications needed........now if you want any others modifications are needed. I went thru this same thing, hopefully someone else can chime in again and back me on this. But it's just my .02cents.
-Joe
-Joe
