Full Turbo Kit for 1300 Shipped
Exactly, this is the kit that GSoup has on his car and he has had no problems with it. Cliffud also has this kit waiting to be installed, and Lexmada has this kit on his car with 7 PSI.
So basically you could buy this, have it installed and you should be good to go? I'm assuming you wouldnt need to tune it if your running low boost?
How do you set the boost without a boost controller? Manually?
you would need a wideband and some fuel management. wideband basically reads a wider range of a/f ratio. Fuel management is to manage a/f. Most wideband kits also come with boost gauge, and exhaust gas temperature (EGT).
https://www.clublexus.com/forums/sho...d.php?t=270853
the hardest part of this project should be the oil return flanges. It requires drilling, taping, and relocation of numerous wires and a few hoses. the FMIC mounting and piping is the next hardest challenge. everything else is pretty much bolt-on and following instructions.
You'd need an SAFC and either a Dyno guy, or a wideband to tune it. You don't HAVE to but it is really suggested. You can get a cheap manual boost controller to control boost or just boost with the 5.5 PSI WG spring that comes with it.
This one is really good quality. The only difference you are really looking at is name. A lot of the boosted GS guys on the forum are using either the XS Manifold or the kit as a whole.
Bleeehhh.. T57.. Weak.. But i think i can deal with that until i have money again.. my car is a daily car so i dont need crazy boost... hmm are you willing to SEMI part out or take out some things from the list?.. I got a gran right now just sitting and waiting to be spent.. Heres the thing, I really dont like the BOV and wastegate that comes with it.. Can we close it out for a gran without those parts?... PM me if anything!
**Edit: How about 1100 with the IC pipes if its made for the GS300. If its not, 1000 shipped without the wastegate and BOV..
