FS: 2nd gen GS Youzealand SS kit rear RCAs
Old 12-24-07, 11:12 AM
Benjamin T
Benjamin T's Avatar
Default FS: 2nd gen GS Youzealand SS kit rear RCAs
***PLEASE NOTE: this fs ad is just for the REAR ROLL CENTER ADJUSTERS ONLY***
brand new. i bought them from japan, and tried to do a test fit, only to discover that they were not compatible with the KMAC camber kit that i have on my GS
i had bought these in conjunction with front RCAs to gain back 25mm of stroke in my coilovers, which were bottoming out on me because i wanted to go low.
their website is here:
http://74.6.146.244/babelfish/transl...t%2f16ari.html
scans of the install paperwork (hope you can read japanese):
some pics:
my price is $300usd shipped within north america. paypal add 3% for fees.
Benjamin T is offline
Old 12-27-07, 08:40 AM
Benjamin T
Benjamin T's Avatar
partial translation of the cover page:
This item is a kit wihch can give you 25mm stroke more because of the bolt-on. It prevent to the minimum of the vehicle hit the ground since it happen to the shortage of the shocking stroke when you lower the body
Coil suspension usually use short spring to lower the body, but after you lower the body, the shock will hit the ground, it also decreases the comfort of the driving and increase the burden to the body, and even will give too much pressure to the rims as well. So you can't have the original performance of the vehicle. But when you use this kits, you don't have to use down-suspension to lower 25mm, you can have normal stroke of shock, and it will remains the original comfort of driving.
About air suspension, you can use the controller to control the height of the body, but when you lower the body, the same problem also happen,
and because of the electrical control, the movement of the shock is getting harder, it cause the decrease of the comfort of the driving and when keep driving this conditions, it give too much pressure(stress) to the air suspension and will cause the damage. when you use this kit to lower the vehicle with air sus, since the stroke of shock can also raise the same vehicle height as former 25mm, the burden of companion a bottom of shock or air sus decreases, and a degree of comfort is also eased very much.
Old 02-22-08, 10:31 AM
GSing430
GSing430's Avatar
any update?
GSing430 is offline
Old 07-08-08, 10:46 AM
Benjamin T
Benjamin T's Avatar
back up for sale due to unforseen circumstances on my part.
please be patient with me if my response time is slow as i am currently recovering from back surgery
Old 07-19-08, 10:49 AM
Benjamin T
Benjamin T's Avatar
bumping bumping
Old 07-19-08, 12:52 PM
kit cat
kit cat's Avatar
d'oh, too bad they're the rears
kit cat is offline
Old 08-01-08, 08:18 PM
Benjamin T
Benjamin T's Avatar
back to the top
Old 08-02-08, 02:30 AM
PHML
Master Thread Closer!!
PHML's Avatar
Wow...those are too beautiful to install.
PM sent.
Pete
PHML is offline
Old 08-08-08, 07:14 AM
Benjamin T
Benjamin T's Avatar
bump.... pm's replied. again sorry for the late responses... still recovering from back surgery
Old 08-20-08, 07:55 PM
Benjamin T
Benjamin T's Avatar
SOLD!
thanks pete... i'm trying to get them out to you asap
go20214
11-02-09 06:50 AM
RaynArt
32
05-29-09 07:00 PM
wrxgs
04-19-09 08:55 PM
PHML
03-10-06 11:37 AM
Kstyle55
GS - 1st Gen (1993-1997)
01-08-05 05:04 PM
Quick Reply: FS: 2nd gen GS Youzealand SS kit rear RCAs
