WTB...Drivers side ABS sensor!!!
Hey just curious.. My ABS/VSC indicators are on. Do you have the same issue?? I am wondering if my sensor is bad too and that's why the indicators are on. But I have not noticed any diference in the car since I have had this assue after I got the car back from the body shop...
Thanks...
Thanks...
Well i have vsc vsc-off and abs lights all on. the car will drive he same but when it needs to use abs or vsc, then you might be in trouble. Get it fixed asap. there are usually bad from lowering the car or hitting a really deep pothole. If you are lucky then its a cable that is damaged if you are not lucky then its the sensor it self and now if you are really not lucky then its the yaw rate sensor 1200 dollars at the dealer. get the codes read for you to see what it is. mine i need a new sensor.....
