FS: A650E Stock GS Transmission
Old 07-26-08, 08:15 PM
JeffTsai
JeffTsai's Avatar
Default FS: A650E Stock GS Transmission
I have an extra transmission laying around in my garage. I was going to get it torn down and rebuilt as second backup race tranny. But I have other "bigger" plans instead(possibly TH400 ). Transmission is for a GS300 but should work for the 400/430 as well since all the GS used the same transmission. If you want to use it on your V8, you will need to use your stock bellhousing since the GS300 engine has the starter off to the side instead of top center. I will also include the torque converter as well, very useful if you need to get a performance high stall converter built and you need a core. Instead of paying the shop $150+ for a working core.
Again this is a unmodified working stock transmission. Great for an extra tranny to be sent off to be built to prevent downtime while waiting for the rebuild. Or just use it as a replacement for a broken transmission.
I'm selling it for about $200 cheaper than other sources because the shift linkage lever got damaged. It will need to be replaced. It's not difficult to do and the parts shouldn't cost much. If you're getting it rebuilt then they will replace the shift rod while they're in there. If you're replacing a broken trans then they can just pull the rod out of your old one and swap it in here.
Selling price $350. Freight delivery cost is about $150.
JeffTsai is offline
favor
03-16-18 07:49 PM
bloodyKnuc
GS - 1st Gen (1993-1997)
06-08-13 06:20 AM
SC400slide
Maintenance
10-06-12 07:28 AM
BLiu
05-02-01 12:32 PM
Quick Reply: FS: A650E Stock GS Transmission
