CA wire harness for 01+ tail lights
You know you can use the 98-00 taillight harness. All you have to do is convert the reverse light. You can use a old signal light harness. It's kind of ghetto, but it works. Haha
you hook up the wires up. break goes with break. light goes with light. signal goes with signal.
you have to cut the reverse light. look for an old car and take there signal light harness and connect it into the reverse. make sure you cut the side rubber thing so it can fit inthe hole. than use black tap to put everything together to keep tight.
you hook up the wires up. brake goes with brake light goes with light. signal goes with signal.
you have to cut the reverse light. look for an old car and take there signal light harness and connect it into the reverse. make sure you cut the side rubber thing so it can fit in the hole. than use black tape to put everything together to keep tight.
LXLUTHR
04-04-18 03:17 AM
