DC FS: 01+ Style Steering Wheel & Toyota Airbag
!!!SOLD!!!
Go for that complete Aristo look with a 01+ Steering Wheel & Toyota Airbag. I got a great deal on a different wheel so I'm changing it up... again. For this, I used a dual stage Toyota airbag which I converted to single stage so it could work in my 98 GS400. I can convert this back to dual stage also so, this could work on any 98-05 GS. Just tell me if you want single stage(98-00) or dual stage(01-05). The tiptronic will only work if you already have it though. Any questions let me know. I have a few other pics I can send if you want them. This does come with the cruise control switch as well so it is ready to bolt on & plug it.
Thanks for looking,
Ki
I forgot to mention that with a little work this can also work on first gen SC's & GS's. Search in your forums for details on how.
Thanks for looking,
Ki
I read up on airbags before I did this. From everything I found converting this to single just gets rid of the partial/weaker deployment. The bag will still deploy, just as a standard full deployment single stage. I bolted a single stage "element" in place of the dual stage. I will let the picture show what I mean. Either one will bolt on and work just fine. The airbag can deploy full or partial so it can be single (full) or dual (full & partial) depending on which way you have it setup.
It would probably leave marks if you pulled it off so, it "could" be removed but I would not recomend it. What are you trying to do?
You could just find an 01+ RX single stage airbag or do what I did and make a single stage yourself. Goog luck with it. If you just need the steering wheel let me know through PM, maybe we can make a deal.
See post #3. It shows how I did it. If you dont know what you are looking at then I don't think you should be messing with airbags. I just unbolted the dual stage from the back of the airbag and bolted on a single stage. There are also ways to wire up the dual stage so it can be used as a dual but I won't get into that here. Just do a search in the SC forum for info on that. I chose to use a factory piece to make it work rather than rewiring.
Yes, this is plug and play for 98-00 as a single or a 01-05 as a dual. Just let me know which car you have and I can send it to you ready to go. At the moment it is set up for the 98-00 single.
$500 Paypal shipped OBO
Go for that complete Aristo look with a Toyota Airbag. I got a great deal on a different wheel so I'm changing it up... again. For this, I used a dual stage Toyota airbag which I converted to single stage so it could work in my 98 GS400. I can convert this back to dual stage also so, this could work on any 98-05 GS. If you get this just tell me if you want single stage(98-00) or dual stage(01-05). The tiptronic will only work if you already have it though. Any questions let me know. I have a few other pics I can send if you want them.
Thanks for looking,
Ki
Thanks for looking,
Ki
So basically i can take the module from my 99 airbag and put it on the 01+ airbags?
