For sale entire show car trunk setup. Two separate sections of fiber glass make up the enclosure which sits down in the wheel well (so no room for the spare tire). One piece goes on the deck lid and has the TV and 6 1/2s. There is a crack in one section of the deck lid which should be redone ( the trunk came down on a metal rod and damaged it but it is very fixable and usually goes unnoticed by anyone looking at the car). They chipped away some of the fiberglass in the rear section of the subwoofer enclosure to make the tanks for my air ride system fit but it is not noticeable at all from outside the car you would have to pull out the enclosure to see it but you may want to redo that section as well. I will take new pictures once I pull it out of the car so that you can see the sections that need work. All audio and video components work very well. It is a show car so it did not get a ton of use and was always babied.
Here is what is included:
2 – Orion 12” Sub Woofers
2 – Orion 6 ½ speakers
10” Directed TV
2 – Orion 600D Amps
1 – Orion 400D Amp
Fiberglass Enclosures
The fiberglass and everything cost me about $3000 I will sell everything for $1000. This item is very heavy so it must be a pick up only deal. Right now it is located in Atlanta GA. I encourage anyone who is interested in it to go and look at it first. PM me for more information or to set up a time to check it out. Once you pull the spare tire section from the car this will fit right in.
that really is cheap.....i think since he has already aquired his new ones, he's just trying to recoop some cost. i dunno. cheap cheap nice setup though
It was very well put together by a shop in Virginia. I would give it a 7 because of the crack in the trunk lid and what they did to make my air tank fit. It is still a very nice setup.
Mark is still a member of Elite of Atlanta. I am now a member of the International Allstars - TeamAllstars.net we are still close and talk a lot. I just chose to go a different direction than the show team I was on before. We are all members of Club Lexus though
