CA rmm supercharger kit
Considering the mileage on mine, and still the exc. cond. of the car. I hope some more of these get out there so the path is paved when mine finally gives up.
LS engines are EXTREMELY compact
lightweight
everything under the sun is avail. for them, and new parts hit the market daily
compared with most anything, except for gen 1 sbc, they are CHEAP
very abundant, anything that is a GM V8 gas engine these days is of LS architecture.
LET'S SEE SOME BUILDS!!
lightweight
lightweight
lightweight
she's caught on and just checks the credit card statements. but if i hide it i can usually stretch the ***** session a couple of days or until she checks the statement's...lol
Yes, but unless you plan on doing a forged bottom end to lower comp. ratio on the LQ9 it won't handle as much boost as the 4. If you're not going to boost it, save about 65 lbs off the nose, and do an alum. block. If you're planning on adding boost very simply the 4s can make 650 rwhp without pulling a valve cover. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Since you're starting your research and poking around in the engine bay some, see if flipping some stock manifolds would work on these cars to put the turbo up front like a lot of the Camaro guys do.
-durable cast manifolds that still flow well
-short hot and cold side plumbing
-saves A LOT of $$ vs. building tube headers
I'll be following this one!
Robert
Robert
theres a shop that sells the sc300 pedals, master cylinder, and all of the miscellaneous toyota parts that are needed for the swap as a kit. Pretty goodpricing on it too. Search out my user name on the FS section, I think I had posted a link to them when I sold my extra set. Im too lazy to search it this morning. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
My 6 spd swap is almost done, and according to my shop, you are right, the pedals are the hardest part in the GS. Not much room to work with, but mine are in and look factory.
he must of really been cussing doing it that way...lol i took the dash out to make it easier to work and i need to cover the dash to match the new interior anyways. ill take pics once i get some pedals for future people doing this mod...
lightweight
lightweight
STARTING TO LOOK AS IF I AM GOING TO JUST PUT IN A MANUEL 5 SPEED R-154 IN GOING TO LOOK AT A TRANSMISSION TOMORROW IF ITS GOOD ILL BE TAKING THIS DOWN SINCE NO ONE WAS INTERESTED. will post tomorrow the results
i like the manuel better for handling anyways going with a t-56 cant find a r-154 then if i want to later i can swap the motor too. mods please close this i am not selling the supercharger anymore at this time...
LSMALC
12
07-03-13 08:38 PM
morris
46
02-17-05 03:32 PM
