If only the color wasnt red... Guess i could just get them repainted. So let me get this straight, I have oem 17's so i would need at 15mm spacer in the front and then i could shave down the tie rod bolt? OR do i HAVE to buy an RCA?
you can just shave off. RCA is just the other option.
GLWS man. i would have bought these if i had the money.
So as I understand it, these bolt directly to an sc300 with no modifications except I'll have to buy the ls400 rotors and pads?
I believe you have to cut or bend your dust shield, which shouldn't be a problem.. Other than that, it should bolt right on. Here's some info on whether or not to get new bolts. Some people recommend it, others don't, it's your pick. https://www.clublexus.com/forums/sus...-calipers.html
Originally Posted by Gennady7
I will take them if they fit.
I have the 3gs 18" 5 Spoke rims. Will these bad boys fit my setup? I really like these brakes.
I have the early 3gen 5 spoke GS rims and Supra TT brakes, they do not clear, I need a 10mm spacer to clear. LS400 brakes are supposed to be similar size, but a little smaller than Supra TT brakes. You might get away with a 5mm spacer, but you're going to need a spacer nonetheless.
