Yea I meant to say the NEO would work if I wasnt clear. If the pin outs are different you can move them. I think there is only 4 wires off the top of my head for the NEO?
Still pending sale for payment. I will update if I dont see it by Monday.
Thanks
Looking at the SRT instructions for the 02+ GS300 & GS430 One would just use different wire for rpm than is on your harness. No biggie, simply just use the SRT diagram.
Someone can even use your harness for the Apexi SAFC II just cut off the NEO connector I'm you need the same connections-pwr,grd,MAF,TPS,rpm knock sensor 1 & 2.
GILLEXUS:
Currious..to the best of your knowledge are the pin outs for the 04 430 the same as passnu2's 06 430?
It should be,engine the same as 01-05 just body changed. If passnu2 or some has a 06 ECU electrical print out I would know for sure unless paccnu2 knows.
I know they are the same but I cant seem to find my PDF on it. I bet if you ask Darrel at Sewell he can confirm or post the PDF for you. The next best option I can take a close up of the pin outs for the NEO. These are the key items to make sure they match as the rest dont matter anyway since they will line back up
FYI...when I was doing this mod I went to my local library and found the ECU pin-out sheets there (in the automotive section). Made copies and brought them home. GL!
