NY Stoptech 332mm ST-40 RED big brake kit
I have for sale a used set of 332mm (13inch) STOPTECH 4 piston big brake kit for sale. I purchased this kit brand new more than a year ago and have only driven the car 6k miles since then. This is a low mileage kit so the rotors and pads still have a lot of meat on them.
This kit comes with 2 calipers, 2 HAWK ceramic pads, 2 HAWK BLUE track pads for the occasion track days, 2x 2 slotted 2 piece rotors, and two ss lines (non stoptech)
As far as performance goes, this is leaps and bounds over the LS400 setup I used to have. The pedal is FIRM, the stopping power is FACE ripping. The difference in performance is just incredible. The new owner of this kit will be pleased!
ST40 forged caliper weights only 7 lbs, rotors are 2 piece so it saves a lot of unsprung weight compared to OEM rotors.
Best part about STOPTECH items are the replacement parts are CHEAP and easily sourced since they are a US company. Kit fits MK4 SUPRA, all years SC300 and SC400, 1gen and 2gen GS300 and GS400..
Price is $1300 OBO plus shipping. Original price was $2,200 when I purchased, this is a great deal for REAL BIG BRAKE KIT!
![](http://i174.photobucket.com/albums/w108/pharmdhc/79a9ce1d.jpg)
![](http://i174.photobucket.com/albums/w108/pharmdhc/IMG_0335.jpg)
![](http://i174.photobucket.com/albums/w108/pharmdhc/IMG_0334.jpg)
![](http://i174.photobucket.com/albums/w108/pharmdhc/IMG_0332.jpg)
![](http://i174.photobucket.com/albums/w108/pharmdhc/IMG_0329.jpg)
![](http://i174.photobucket.com/albums/w108/pharmdhc/IMG_0327.jpg)
![](http://i174.photobucket.com/albums/w108/pharmdhc/IMG_0324.jpg)
Do you have any idea how many more MM i need vs stock calipers? I'm not too familiar with the spacing difference... I have a set of trafficstar's 18x10s in the front with negative offsets... I can see I have only about 5-10 mm of clearance... but I am willing to run some spacers as long as it isnt overkill to make them fit..
Thanks
Thanks
OK, here is the template you will need to check whether or not your wheels will clear these brakes.
http://www.stoptech.com/tech_info/ch...57-2450-00.pdf
This is the instructions to go with it.
http://www.stoptech.com/tech_info/wheel_fitment.shtml
Basically you print out the template, the match it up to the hub of the wheel, if it does not touch the spoke then you clear, you will need at least 2mm of space between the spoke and the caliper. If your wheels are high disk then I'm sure they will definitely clear.
PM me with offers or questions. This is a great deal, don't sleep on this, it will be gone FAST!!
