CA GS430 supercharger kit
#34
21 mpg when I'm not jumping on it.
Also I'm running stock cats and am running CLEAN when smog tested.
Too bad I don't pass visual, but I have some friends
Awesome set up BTW
$4500 is a great price. You can't duplicate this kit for that amount of money.
#35
Off topic but...not true. It has been proven that the stock GS4 tranny can operate as it should up to or very close to 400whp. This kit is making that if it is lucky. Typical SC kits at 7-8psi make around 370-390whp if tuned properly IIRC. These power levels are without any supporting mods such as headers etc etc.
I second this comment too.
I have 400rwHP and have been boosted for 5 years with no tranny issues.
#36
Thanks for the info RMMGS4!
#40
This is a complete plug and play kit for a GS430. Everything you need is included with the kit down to every bolt. I will also include detailed instructions so you can install the kit on your own. Not sure what the difference or if there is any difference with installing this in a GS400.
#41
#42
#43
I'm pretty sure you would have to modify the pipe where the mass airflow sensor bolts on. The gs400 mass airflow sensor is a different shape, different size hole in the pipe and bolts on differently. You can check the srt page they show pics of the gs400 and gs430 mass sensor mounting plates.... but they might both have the same connecter.
#44
