CA BC Racing or TEIN Coilover ((Springs ONLY)) 12kg / 10 kg
These springs were removed from a brand new set of BC Racing coilovers.
They also fit TEIN and probably others coilovers as well. I'll post the dimensions of the springs if someone needs it to verify they fit.
Front springs have zero use, rear springs were installed, but then removed after 50 miles.
So who would want these? Anyone who has been riding on a coilover setup with springs that are one step stiffer or softer than these and want to try a different spring rate to get the car riding how they want it. This is a much better alternative to buying a whole new coilover set up, especially if you like your current set up.
Spring rates are 12 KG Front and 10 kg rear. This is a very popular spring rate set up that provides decent stiffness while not riding hard, especially when slammed. Do a search on BC Racing reviews if you want to read other feedback on this spring rate combo.
So if your current springs are 2kg stiffer or softer than these springs and your coilovers have adjustable damping, then these springs should work ok on your shock.
$ shipped to lower 48 states. Priority goes to local NorCal members 1st , SoCal 2nd.
![](https://www.clublexus.com/gallery/data/500/springs2.jpg)
150shp
150shp
Thanks for the feedback.
These are good for people who have softer set ups like a TEIN CS and want to bump up the spring rate to the next level.
NOTE: I actually am still running the same spring rate as these springs, but switched over to a shorter length spring with the same spring rate to make allowance for the cup kit I'm installing.
vpspecialk
11-09-15 04:05 PM
