VA FS: OEM Oil Cooler assembley from Aristo GTE, fits GE also.
This is a complete OEM Aristo GTE water cooled oil cooling assembly. This will also bolt directly to a GE block to add oil cooling. I am including the rubber hoses, clamps, and the threaded nipple needed to screw into the block to get the water feed (stock GE has a threaded plug in the location for the nipple).
$55 shipped to the 48 states
Sorry I don't have any direct temperature info to share. But it is an oil cooling system, so it will defiantly help keep oil temps in check. If you drive for long periods of time, sit still in traffic alot, or drive hard then oil cooling can be beneficial to most any vehicle.
Epik
06-09-12 07:25 PM
onejapman
11-17-09 09:20 AM
1siksc
Performance & Maintenance
12
10-29-08 07:19 PM
