FL FS: V160 OS Giken Twin Disk Clutch
*********** SOLD ************
Suited for V160/ V161 – 6 speed getrag
OS-Giken clutch kit is complete and includes the following
- Lightweight Flywheel
- Flywheel Bolts
- Twin Plate Clutch
- Pull – Push converter kit
This clutch has less than 2000 miles of street driving on it, it has never seen more than 530 RWHP. The clutch disks and the other two sandwich plates were purchased new from OSGIKEN last year.
This has to be one of the best clutches out there; it’s perfect for drag / circuit. Can hold around 750 horse power with the steel cover. It rattles only when engaged at idle. Whilst driving in low rpm this clutch does not rattle at all. Its rated higher than excedy and extreme clutches
Price Drop to $850 over 70% wear remaining on the disks.
![](http://i55.tinypic.com/2uhr05y.jpg)
Through rigorous research and development of high performance engines, we realized the need for the production of higher quality, more durable clutch systems to meet the rigorous demands of race and sport driving. OS Giken multi-plate clutch is able to transmit engine revolutions and output to the drivetrain without loss. They are made of the highest quality materials and their durability is second to none. OS Clutches are designed to meet the demands of even the most heavily modified vehicles.
In spite of its decreased diameter, OS Giken clutch allows for extremely efficient power transfer and improved engine response. OS Giken redesigned leverage mechanism of the diaphragm spring on the center cover results in higher pressure of the clutch disk while reducing pedal effort. In addition, ventilation holes are designed to reduce heat generated inside the clutch system and allows for the friction plate dust to exit outside the clutch system, thus increasing reliability and safety. All OS Giken clutches include a corresponding performance flywheel to ensure maximum performance and unlock your vehicle’s potential.
Application: Toyota Supra JZA80
PRESSED STEEL COVER, 215MM Plate Diameter, Twin Plate w/Damper.
- Flywheel Bolts
- Twin Plate Clutch
