FL LS400 Brakes and Rotors
Master Thread Closer!!
would i need to purchase RCAs in order to mount these on an SC. respond to jasonlyon1964@yahoo.com thank you
Optional upgrades...stainless steel brake lines....and upgraded brake pads.
Also, since the LS400 is larger, you need to bend or cut part of the rotor shield to mount them. Its a direct bolt-on...no brackets required...use oem existing bolts. If you are running stock wheels, you will need hubcentric spacers to prevent the wheel face/spokes from hitting the LS400 calipers.
https://www.clublexus.com/forums/sus...o-rubbing.html
Good luck..if you have questions...just ask.
Pete
PS....bump and vouch from MistaSC.
