TX Futura Design Big Brake kit. 8Pot Front and 6Pot Rear
Up for sale is my set of Futura Design Big Brakes in Gold anodized color.
8Pot front with 380mm rotor
6Pot Rear with 356 mm rotor
Steel braided lines
Bracket for 2GS
Setup has only seen 700 miles the most, so rotors and pads are in almost new condition. Selling because these won't fit my new project.
Install is a direct bolt on for a second gen GS300/400/430.
I believe you can purchase the bracket for your specific car if you do not have a 2nd gen GS300.
Onto the pics:
Front:
20in OZ futuras using 25mm spacer
![](http://i50.tinypic.com/2ezjj9d.jpg)
19x9 -4 Step lip Leon Hardiritt Herzog, High disk using 5mm spacer due to the bolts on the back of the wheel slightly hitting the rotor.
![](http://i50.tinypic.com/28cewaw.jpg)
Rears:
20in OZ futura mid disk using 5mm spacer
![](http://i46.tinypic.com/5a2f4o.jpg)
19x11 +11 Step lip Leon Hardiritt Herzog, High disk using 5mm for the same reason above
![](http://i50.tinypic.com/magsgx.jpg)
I am asking for $3600 shipped OBO or $3400 picked up
If you are using paypal I can split the fees with the buyer.
Thanks for looking!
Steel braided lines
Bracket for 2GS
Onto the pics:
Front:
Rears:
Thanks for looking!
Here's what I got from their site:
"All Futura Design calipers are T6061 forged aluminum. Mounting hardware Brackets are High pressure cast iron. Calipers are equipped with a quick release brake pad retainer bracket.
The pistons in Futura Design calipers vary in size, this method is used to stabilize surface pressure in pads and improve braking balance, Thus giving you a consistent and frictionless braking experience."
Also these are the same bbk's that 326 power in Japan sells/uses.
They look sick for sure. And at 380mm on the front that's damn 15" rotors, and the rear at 356mm is a 14", defiantly hot **** on a GS.
AMSMIKE
30
07-22-12 02:31 PM
illmike
03-31-09 05:27 AM
