IL New FIGS Adjustable Length Toe Links & Rear Struts/Coils
I recently purchased a set of new adjustable rear toe links from FIGS Engineering to fix my tire wear problems. However, an alignment at the Lexus dealer, along with new rear upper control arms, fixed my issues. This part is also useful if you are lowered and want to get your rear toe back to spec.
I never installed the toe links, and they are brand new in original packaging. They are the mid-range Motosports grade, and FIGS powdercoated them to protect against corrosion.
FIGS is selling this item for $250 (Motosports grade and powdercoating), but I will let them go for $220 shipped or $210 around the Oakbrook IL area.
I am also selling two used rear strut/spring assemblies from my car. They're in decent shape with minimal corrosion. Miles on the struts are unknown, but they didn't seem blown when I swapped them out. I probably shouldn't have swapped them out at all--I just removed them to try and solve the tire wear issue, but they weren't the culprit.
$50 local, $80 shipped for the rear struts.
300, 9805, adjustable, adjustable toe links, figs, gs, install, link, links, ls400, rear, rear springs, rear struts, toe, toe links
