CA Selling lots of stuff. SAGE KSPORT RMM OEM etc
#39
[QUTE=vwynn;7668361]Price Dropped 1/10/13
Please read the this top piece first.
Have some parts for sale from my GS400. These parts are off my Daily car so all they see is freeway and street driving. Mainly freeway since I commuted a lot back then. Some of the parts are still on the car however they will be off within a week. Pics will be up as well.
Prices: Pickup price. Shipping is extra and needs to cover all shipping expenses including material needed to pack since I might not have any here. Please just generate a rough estimate of shipping cost via Fedex
Payment: Paypal or cash. PM for paypal info if you want to quickly seal the deal.
Cliff Note:
Sage RCA Sold
Toyota Aristo Visors Sold
RMM (Supra TT) Brakes Sold
New Rear GS400 Rotors Sold
Intrax Sway bar Sold
Passenger HID Headlight $100
Driver HID Headlight $40
LS460 Projectors + Bracket + Clear $325
G35 Projector + Clear $120 $100
555/MOOG outer tie rod (L+R) Sold
MOOG outter tie rod ('R) $15 $10
Ksport Air suspension + Easystreet $2,250
RMM Mufflers Sold
LED Tails Sold
______________________________________________________
Brand: Moog
I have 1x new never mounted or used MOOG outer tie rod. This is an extra and is MOOG with zerk fitting.
Comes with:
1x Right MOOG outer tie rod
![](https://www.clublexus.com/forums/attachment.php?attachmentid=268161&dateline=1357262121)
_______________________________________________________
Brand: OEM
Passenger HID Headlight.
Used HID headlight. Nothing wrong with it besides the small scratch on the lowbeam. Comes with the ballast, and motor n what not. Only needs the bulb. All tabs intact.
![](https://www.clublexus.com/forums/attachment.php?attachmentid=268162&dateline=1357262121)
![](https://www.clublexus.com/forums/attachment.php?attachmentid=268163&dateline=1357262121)
Brand: OEM
Driver side HID Headlights.
Used driver side. Its already opened and can be only used for parts and the auto level has been damaged priot (not by me). So yea that’s about it. I tried to do my LS460 retrofit on it as a practice set but stopped since yea.. not modding the car anymore. Good to use as a practice set
Comes with: Driver side headlight assembly, ballast, n what not.
*does not come with projector or bracket... Bezel has been trimmed to fit the ls460. but can retrim for projectors like Q45.
![](https://www.clublexus.com/forums/attachment.php?attachmentid=268164&dateline=1357262121)
__________________________________________________________________
Brand: Lexus
Lexus LS460 HID Projectors + Luxury Mod Bracket + Clear.
Have a set of HID projectors and clear lens from Retrofit source. One of the lens has a small chip on the corner but other than that it’s in good condition. One projector has been trimmed down for the retrofit install but needs to be grinded down some more to fit the 2GS housing. The other (passenger) is still unshaved. Comes with Luxury Mod bracket for the HID Housing. The headlights are already drilled and tapped and ill include some hardware for your install.
Comes with:
2x LS460 HID Projectors
2x STI-R (I believe) Retrofit Source clear lens
2x Luxury Mod Bracket for 2GS HID Headlights
Misc screw/nuts for retrofit
![](https://www.clublexus.com/forums/attachment.php?attachmentid=268165&dateline=1357262121)
Brand: Infiniti
G35 Bi-xenon Projectors + Clear
Have a set that I was going to install on the highbeam area. One of the projectors i trimmed off the ears to make it rounded for the install and the other has been left untouched. I have removed the circle clamps that held the lens and have the clear lens ready for install. Both projector has been tweaked for crisp cut off and both highbeams work last I recall.
Comes with:
2x G35 bixenon Projectors
2x FX-R Clear Lens
![](https://www.clublexus.com/forums/attachment.php?attachmentid=268166&dateline=1357262121)
![](https://www.clublexus.com/forums/attachment.php?attachmentid=268167&dateline=1357262121)
Brand: Ksport & Easystreet
Selling my air suspension kit. It’s a combination of Ksport and easy street. Originally I was using the ksport management system but I wanted to go digital and I wanted to control each corner so I purchased the digital setup from Easystreet. I have roughly 20k miles on these and it comes with LOTS of extra stuff… This whole entire kit cost me a lot so I know im losing a crap ton of money but oh well.. there are a few caveats though.
1- Rear shocks. Lower sleeve thing seems seized. I never really tried to adjust em so they have never been placed on the vice or anything. I just decided I didn’t want to do it.
2- Rear driver side bag slowly leaks occasionally. Sometimes the car will stay up for weeks without needing air and sometimes itll drop within several hours. Could be an oring going out in the bag (possible easy fix)
3- 2 front bags look newer than the rear because I replaced the front double bellow to sleeves.
Other than that.. I believe that’s it Its a plug n play setup... Comes with a lot of stuff so here goes….
Comes with:
4x Ksport Shocks + 4x Sleeve bags
2x Ksport double bellow front bags (can be used as spares. Have very slight rub marks)
Misc ksport parts
5 Gallon Aluminum Tank
2x Viar 380cc
2x SMC Full Metal water Trap
2x Easy street aluminum manifold (FBSS Setup)
EasyStreet management system + Digital controller. Has all the pressure sensors needed. Will include retrofit wire harness too! Found that not too long ago.
All fittings needed to get you going and comes with 1/4th lines.
Will include Ksport Tank as extra + their electrical / Valves if I find em so you can use the wireless FOB if you please.
I have extra fittings to convert it all to 3/8th lines if you want as well and have 3/8th lines already cut (I think.. somewhere)
![](https://sphotos-b.xx.fbcdn.net/hphotos-snc6/269377_10151247558653227_425964606_n.jpg)
![](https://sphotos-b.xx.fbcdn.net/hphotos-prn1/543977_10151247558138227_319655358_n.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash4/394848_10151247589273227_2079378263_n.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash4/408516_10151247589598227_353185321_n.jpg)
![](https://www.clublexus.com/forums/attachment.php?attachmentid=268168&dateline=1357262121)
Brand: Lsportline
Lsportline Poly Side skirts painted in Alpine silver. Has some scruffs and paint chips but overall solid piece.
Comes with:
1x Right side skirt
1x Left side skirt
![](https://www.clublexus.com/forums/attachments/2gen-gs430-400-300-classifieds-98-05/268172-selling-lots-of-stuff-sage-ksport-rmm-oem-etc-img_7017.jpg?dateline=1357262121)
__________________________________________[/QUOTE]
Hi
Did you have the Ksport Air suspension? And how much to send to 77053
Cliff Note:
Sage RCA Sold
RMM Mufflers Sold
LED Tails Sold
Brand: Moog
Comes with:
Brand: OEM
Brand: OEM
Brand: Lexus
Comes with:
Brand: Infiniti
Comes with:
2x FX-R Clear Lens
Comes with:
Misc ksport parts
2x Viar 380cc
Brand: Lsportline
Comes with:
1x Right side skirt
1x Left side skirt
Hi
#40
Yes i do.
please see this ad.
https://www.clublexus.com/forums/2ge...anagement.html
as for shipping im going to have to look into that since there is a lot of stuff to be shipped out.
please see this ad.
Danny365N
16
05-12-16 11:43 AM
