I hope so but I called Lexus and was told they made 3 or 4 different throttle body assy those years...
I need # 22030-46150..
They also make 22030-46220, or 22030-46180 , and 22030-46120 for same year GS and IS that will bolt on to the same engine but I was told they are not sure if it will work because per my VIN I need a different part.
Can someone confirm you can interchange throttle body assy for GS's....
You should have asked Lexus what is the difference between these part numbers.
"Different years and models have a different version of the same part, voltages and sensor par # differ depending on the year and make even tho same basic engine"
Lexus.
hang tight, i sold a 2004 throttle body to a member here, i am sure he will post if it dont work on his 2000.
I am the dude that bought the tb off "aliga" and it was for my 1998. I installed it removed the codes connected the sensors and wuala! I only drove it for 2 ish miles but tried everything to make the cel come back on and nada. I believe there is no diff on the tb's from 98-05 man. If anything hold for a week meanwhile I drive it more and I give you an update. I'm the one the pm'd you too.
