NY 98-05 FIGS rear knuckle lower rear press-in spherical bearing
Old 08-18-14, 10:42 AM
neegroy
neegroy's Avatar
Default 98-05 FIGS rear knuckle lower rear press-in spherical bearing
BRAND NEW REAR KNUCKLE LOWER REAR PRESS-IN SPHERICAL BEARING
This one has been on the list for a long time and we finally made it happen. A press-in replacement for the rear knuckle where the lower control arm mounts.
While the stock bearing has rubber boots, these feature a teflon lined Aurora or FK spherical bearing for highest strength and long term use on the track or dual purpose vehicle. We have tested these bearings in track duty so you know you are getting the highest quality solution.The bearing is self-cleaning and self-lubricating so boots will not trap in contamination.
Set includes 2-Bearings in bearing cups with retainer clips and stainless High-misalignment spacers to replace BOTH sides.
A bearing service tool (large C clamp) with cups for both sides is suggested since the bearing will need to overtravel to be centered in the knuckle.
http://shopfigs.com/v1/index.php?rou...product_id=129
$150 shipped.
neegroy is offline
Old 08-23-14, 11:59 AM
neegroy
neegroy's Avatar
LEGGGGGGGGGGO
SATURDAY BUMP
bump me
neegroy is offline
Old 08-29-14, 06:09 AM
neegroy
neegroy's Avatar
SOLD! to baddis es, thanks bro.
neegroy is offline
T0ked
Suspension and Brakes
01-13-04 10:39 PM
Quick Reply: NY 98-05 FIGS rear knuckle lower rear press-in spherical bearing
