CA Titan Motorsports 2jz cam bolt
Up for sale is (1) brand new Titan Motorsports 2JZ Cam Bolt. Not only does it look good, its a high quality and strong ARP 2000 bolt. Titan Motorsports only sell these bolts by the pair. Only needed one for my 2JZ vvti Aristo motor. Still wrapped in the package is the (1) bolt for sale. $24 shipped (Paypal) and its yours.
Description:
After extensive cam testing we have found that the stock cam bolt for the 2JZ-GTE engine is not optimal when aftermarket modification have been performed. Stock cam bolts do not break, but we have found when spinning past the stock rev limiter that the bolt is not as effective and would require a new bolt that can be torque down more. Titan Motorsports has developed the only Cam Bolt on the market to fix some issues with harmonics as well as made it more appealing bolt to install on the car.
This bolt needs to be torqued down more than the factory to also achieve the greatest benefit. With oil or ARP moly lube the torque should be around 70-73 ft/lbs
Description:
