FS: 2001 Aristo V300 2JZ-GTE VVT-I Motor and Transmission
I am selling my 2001 Aristo JZS161 V300 2JZ-GTE VVT-I Motor and Transmission that I was going to use for the V300 swap into my GS300. I have decided to venture into a different project and have decided to let this one go. The engine and all other components are located in So. Cal and are available immediately. Below are details of the all the engine parts included:
2JZ-GTE VVT-I with stock ceramic twin turbos - est. 12k miles
Complete with ECU, engine side harness, fuse box, etc.
Brand New V300 Engine Mounts
A340 4spd Automatic Transmission
V300 Dash Cluster - Speedometer, Tachometer, Fuel/Temp Level Gauge
Asking $4500
(attached Image is not of exact motor, but represents the 2jz-gte vvti)
Below are other associated parts are available separately as well:
Link
HKS Racing Suction Intake Kit for JZS161
HKS (New) R-Type Intercooler Kit
HKS Aluminum Pipe Upgrade kit
HKS AT Transmission Cooler
HKS Turbo Timer Harness - Plug in for GS
Please respond here, PM, or email me at jza8shwoff@aol.com for inquires or more information.
Asking $4500
Link
I cant tell you how tempted I am!!!
Im just trying to figure out how much stuff is involved in doing the swap, and who I can trust to do it around here.
HKS, if you can shed some insight on the swap issues I would appreciate it. You can e mail me directly at TTurboPimp@aol.com. I know your boys over there at HKS know what it takes to do the swap.
Thanks
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Thanks
how much for the swap and all the other stuff too?
how about the driveshaft?
would there be anything else i would need for this swap?
PM or e-mail me terrytcl1@hotmail.com
Sorry for the late reply, its been really busy at work.
TTurboPimp
Where are you located? As for what is involved and issues, there isnt a major amount, but by no means is it "simplistic" per say either. email me at jza8shwoff@aol.com with some questions you might have, and I'll answer them and more.
TerryTCL
does it include the alternator, a/c compressor, ps pump?
Yes, its a complete motor. I made sure of that when I sourced it.
The cost for the installation depends on the shop. I do have some referrals in the LA area. As for the other parts I have another post with all the other accessories and hardware that I bought for the swap
Here is the link: HKS Aristo parts
A custom driveshaft will be needed, but the core base for it is not a hard item to get. I just didnt get to the point of doing that part yet, so I dont have one for sale with the rest of the parts.
I think most of it is covered, aside from the driveshaft, but email me for details.
Thanks
Will
TTurboPimp
TerryTCL
Thanks
Will
The GS400 trans will probably bolt up, but I would not recommend it. The gearing wouldnt be ideal for the motor, let alone that ECU and electronics may not like the differences between the transmissions.
Will
Will
