CA FS: IS350 front brake set with extras.
I have a full set of front IS350 brakes for sale. Here is what will be included in the kit:
Both Front Calipers (Used)
Both Front Rotors (Used)
Both Front 350 Brake Lines (NEW!)
Both Front Backing Plates (Used)
Dust-less Pads (NEW!)
Pad Shim Kit (NEW!)
Caliper Fit Kit, Pins, Etc (NEW!)
Tube of Toyota Brake Grease
I can even throw in a couple bottles of fluid.
The Calipers need to be cleaned up, but they are in good shape, and ready for you to clean, then paint or powdercoat. The rotors could be resurfaced, but they are straight and not warped. I can resurface them for a small fee. Two of the pistons in one of the calipers popped out, but i put them back in, and they are fine, but i am including a brand new seal kit for that caliper in the event that the new owner wants to rebuild it.
I will not ship this set! It is wayyy to heavy! I am located in Fremont, Ca, and work in Oakland.
I am asking $550 for this set, and am open to offers. I will post pictures shortly.
4/26 Price Drop to $500/obo.
Pad Shim Kit (NEW!)
Pad Shim Kit (NEW!)
Pad Shim Kit (NEW!)
they do clear out the 17"...
question?
when u put them on ur 250, did u run into anyproblems with the brake system or not!!! cuaz i talked to someone here in TO, who changed brakes from IS250->IS350.. and he had major issues with ECU reading ( i think it was the ECU reading) but i do remmber his car giving errors!!! if u can update me on that..
question?
question?
question?
question?
question?
