CA IS250/350 Custom enclosure, 2 DC Lvl 3, Hifonics BXi 2006D
1. Products:
Custom enclosure for IS250/350
2 12" DC Lvl 3 subs
Hifonics BXi 2006D
- includes bass ****
For those who don't know about DC subs, they are high quality grade subs. They are extremely popular in SPL cars who compete in SPL drags. They blow away anything you can find at best buy or w/e. Kicker or Alpine doesn't come close. I would say they are even better then the JL W7's
The box is done right with t-nuts and machine allen screws
The sub does not hit the grills even at full excursion
The connectors are neutrik speakon connectors but the regular box spring loaded plate is there if you want to use that instead.
Reason for selling: can't handle the bass and rather buy new coilovers
2. Specs:
Enclosure:
- 3/4" and 1/2" MDF Construction
- Black automotive speaker carpet
- Holds 2 round 12" subwoofers
- Divided into 2 seperate Chambers
- 1.15 cubic feet per chamber
- 9.5" mounting depth
- Roughly 25 lbs
- Round spring loaded terminals
- Sealed air tight with liquid nails caulk
Subs:
DC Lvl 3 12"
DVC, 4 ohms per coil. 600w RMS per sub, but can handle a lot more
Really good SQ in small sealed enclosure and can get insanely loud.
Amp:
Hifonics BXi 2006D
* RMS Power Ratings:
o 1 ohm: 2000 watts x 1 channel
o 2 ohms: 1300 watts x 1 channel
o 4 ohms: 650 watts x 1 channel
* Dimensions: 16.50"L x 10.39"W x 2.63"H
* 1-year SonicElectronix.com warranty
includes bass ****
3. Descriptions/Condition of all items:
- Everything is in excellent condition except the following:
- 2 areas of rubbing on the surrounds, only cosmetic though, no hole, sounds great
- **** has slight blemish
4. Total Price: :
Special price for locals: 500 for everything
600 OBO I'll eat the paypal fees
Shipping at buyer's expense
I am located in 94132 or 95348
5. Pictures:
![](https://lh6.ggpht.com/_DGdWFojGIpk/TH7OIBl_ufI/AAAAAAAABnM/NR-Fd-_hrPk/s912/IMG_5721.JPG)
![](https://lh3.ggpht.com/_DGdWFojGIpk/TH7OMv5KgCI/AAAAAAAABnQ/OYZTjSYs7UA/s912/IMG_5722.JPG)
![](https://lh3.ggpht.com/_DGdWFojGIpk/TH7OQ9S5JKI/AAAAAAAABnU/BpLFRRDQL8M/s912/IMG_5723.JPG)
![](https://lh3.ggpht.com/_DGdWFojGIpk/TH7OTGzA8dI/AAAAAAAABnY/fZBRZcIZsBY/s912/IMG_5720.JPG)
![](https://lh5.ggpht.com/_DGdWFojGIpk/TH7OXtnUTQI/AAAAAAAABnk/tRAuWa_dq28/s912/IMG_5719.JPG)
![](https://lh6.ggpht.com/_DGdWFojGIpk/TH7OdvvlQAI/AAAAAAAABn0/i-YMJIB3C44/s912/IMG_5718.JPG)
![](https://lh4.ggpht.com/_DGdWFojGIpk/TH7OgnKvRuI/AAAAAAAABn4/zL-YtPyyNUg/s912/IMG_5717.JPG)
![](https://lh3.ggpht.com/_DGdWFojGIpk/TH7OiK5cVvI/AAAAAAAABn8/-N8LXbUDH68/s912/IMG_5716.JPG)
![](https://lh5.ggpht.com/_DGdWFojGIpk/TH7OjqT41nI/AAAAAAAABoA/ZBSUq0YGSR4/s912/IMG_5715.JPG)
2 12" DC Lvl 3 subs
Hifonics BXi 2006D
2. Specs:
Enclosure:
- Roughly 25 lbs
Subs:
DC Lvl 3 12"
Amp:
Hifonics BXi 2006D
includes bass ****
4. Total Price: :
5. Pictures:
I had it for 8 months or so. Like I said, I couldn't handle the bass so the **** was always set to the lowest.
PM sent
All good, thanks
Stock navi with line out converter (high low converter) on the factory sub channel
I can include a free line out converter if buying needs one.
I can also include the KNU (oversized good stuff) 1/0 wires and fuse holder for extra if the buyer wants. This will make getting it running a piece of cake.
It also uses high quality high current quick connectors for the main power to the amp. I run these on all my builds for quick disconnecting if needed. Even the remote turn on power line uses a deans connector.
The gain **** was less then half way. I set it to about 1000W. The method I used was set up a multimeter to AC mode and measure the output voltage on the amp. Then I referred to a chart that is used a lot on audio forums and audiophiles.
