CA FS: vled module, LED DRL, and LED parking lights
sold!!!!!
I have a set of used LED DRL (9005 bulb I bought from ijdmtoy), vled 9005 module (which I've bought from v-led.com) so it doesn't flicker, and 168 LED parking lights.
All have been used for several months. Still in top notch conditions, works great, and plug n play. Pictures are below. Asking for $50 total. Buyer pays for shipping. It's all packaged and ready to go.
Question about the DRL 9005 bulbs, which are also the high beam lights. These also work as the DRLs and the High Beams correct? When acting as the DRLs are they running on a lower power, that still show as a white/blue color and not the stock yellow color. Also, when you hit the high beams they do get much brighter and act as high beams, correct? Thanks
Yes, they are the same bulbs as the high beam lights, but you'll lose the high beam functionality since it's a LED bulb.
When they're running as DRL's, if you don't have the module, the light looks dimmed and it flickers. The module prevents it from flickering so you'll have full power. The color is whitish blue. It looks good during the daytime.
When you hit the high beam, while having your low beams on, it'll light up with your low beams, but it'll stay the same power and brightness as when they're functioning as DRL.
Thanks. I use my high beams quite a bit as my Garax 6000k hid low beams don't light up nearly as much as the stock lights. Soo I would be worried it wouldn't provide enough light.
