OH LMS Supercharger Kit for ISx50 complete - Procharger C2 original!!
SOLD - Thanks for all the interest!
Here it is - a complete LMS supercharger kit for the 2006+ IS250 or IS350. I only used this kit sort of as a template to fabricate my own personal S/C setup. All parts are as is from the original owner in Illinois who used this for 13k miles on his IS350. I purchased the kit with the C2 Procharger needing a new bearing and oil seal. I rebuilt the C2 Procharger with seven all new high speed ABEC-7 bearings and two new CR viton oil seals. The gears, shaft, etc. are all in great shape - this unit is ready to be installed and enjoyed at 5.5 psi or 7 psi.
Everything that LMS originally sold with this kit is included for install with the added bonus of my machined studs and billet spacers for perfect pulley alignment and zero belt slip. This should be a huge improvement over some of the kit versions I've read about over the years.
`FMIC core 20 x 6 x 3.5
`x 6 intercooler pipes
`x 14 t-bolt clamps
`x 9 silicone couplers
`5' vacuum hose
`HKS SSQV blow off valve
`Gates K060288 s/c belt
`x 2 Dayco s/c belt routing pulleys
`Crank pulley
`S/C mounting bracket specific to C2 blower
`K&N 3" air filter
`x 3 bracket mounting studs
`x 5 billet spacers (3 bracket, 2 pulley)
`All nuts / bolts
Luv your car all over again with much needed whp added! 5 lbs of boost brings the car safely to life - drives like stock only with added power!!
SOLD shipped and paypal'd as a gift or add 3%. Dont miss out!
You can read about my S/C background and see the bearings installed on the C2 unit here...
People that have dealt with me know I'm legit and go the extra mile to help forum members out!
SOLD
![](https://img716.imageshack.us/img716/8530/imagegdfj.jpg)
![](https://img839.imageshack.us/img839/695/imagentbt.jpg)
![](https://img545.imageshack.us/img545/2207/imageusg.jpg)
![](https://img849.imageshack.us/img849/7638/imagevdt.jpg)
![](https://img337.imageshack.us/img337/1010/imageypz.jpg)
![](https://img28.imageshack.us/img28/4220/imagexipv.jpg)
SOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLDSOLD
`x 14 t-bolt clamps
`5' vacuum hose
`Crank pulley
`K&N 3" air filter
`All nuts / bolts
SOLD
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Thanks everyone
All PM's replied to...trying to be as descriptive as possible as some really good questions have been asked. I can tell whos serious and whos not.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
The kit includes a 2.55 S/C pulley.
I should mention that if used on an IS250 with a 2.55 pulley you will produce close to 7 psi. If an IS250 buyer wants 5 psi a 2.65 or 2.70 pulley will need to be purchased for $82. I can arrange this or tell you how/where. I'm including two belt sizes so you're covered regardless with that piece.
If used on an IS350 with a 2.55 pulley you will produce 5.5 psi.
