Looking at grabbing a F-Sport Front Sway Bar, would be nice if I can find someone local to Baton Rouge/New Orleans/Lafayette areas. I know they rarely come up on here, but it's worth a shot. Otherwise, I know Bell Lexus still has some in-stock.
You can also try finding a used IS-F front sway bar which has the same thickness as the F-Sport front sway bar.
Ah, thanks for the heads up about that. I completely forgot about the IS-F bar. Wasn't there some sort of difference between the two though, iirc, I recall someone (probably Jeff) saying the F bar was either lighter or thinner than the F-Sport bar by a bit.
I know for sure that the rear IS-F sway bar is slightly smaller than the F-Sport rear sway bar (17mm vice 19mm). To my knowledge, the front IS-F sway bar is either identical or near identical to the F-Sport front sway bar.
