Does 2005 LS 430 come in 2 pacakages? Modern Luxury or Ultra Luxury? (Merged)
I need to find out more about the LS430 that I am buying through a dealer at the auction. The car has a ML package, rear view camera and NAV etc., It does not talk about Blue tooth anywhere. Does this come with the bluetooth as well?
Can I call my local lexus dealer and find out about it? Would he also be able to tell me when does the 4 year warranty expire?
Can any one alos tell me where I can find the cheapest quote to obtain an additional 5 year/75000 miles extended warranty for the car?
Thanks much
Mike
mrajayya@yahoo.com
Thanks much
Mike
mrajayya@yahoo.com
What do you all think of IPOD and Bluetooth phone integrated technology?
http://www.scosche.com/scosche.bluetooth
On a 2005, if you have Navigation, you should have Bluetooth.
If you don't have Nav, get a Garmin and you can get Nav and Bluetooth. I bought a Garmin 650 at Costco for $470 two weeks ago, but they don't show that model on the web, today. It was the lowest price I've ever seen for that unit and IMHO it beats the pants off the 2005 Lexus factory nav.
Please use the search future next time, all the info is readily available.
from Lexus model library:
http://www.lexus.com/cpo/model_library/LS/2005.html
Available Options:
Ultra Luxury Selection
- Mark Levinson® [6] 11-speaker 240-watt [7] Premium Audio System
- Lexus voice-activated DVD Navigation System [10] with backup camera [11] and Bluetooth® [12] wireless technology
- Dynamic Laser Cruise Control [8]
- Adaptive Variable Suspension
- Laminated side glass
- Manual rear-door window sunshades
- Intuitive Parking Assist
- Front and rear climate-comfort seats with heat/cool ****
- Headlamp washers
- Power door closers
- SmartAccess
- Rear-Seat Luxury Group:
Power slide seat adjuster with power headrest, with memory and massager
Air conditioner controls with Air Purifier
Cool box
Audio controls
Swivel-type reading lamps
Ultra Luxury Selection with Pre-Collision System (PCS)
- Dynamic Radar Cruise Control [13]
- Pre-Collision System (PCS) [14]
- Adaptive Variable Air Suspension
- Headlamp washers
- SmartAccess
Cool box
Audio controls
Custom Luxury Selection
- Lexus voice-activated DVD Navigation System [10] with backup camera [11] and Bluetooth® wireless technology [12]
- Front climate-comfort seats with heat/cool ****
- Headlamp washers
- Rear-seat heaters
- Perforated leather seating surfaces
Custom Luxury Selection with Pre-Collision System (PCS)
- Headlamp washers
- Rear-seat heaters
Premium Package
- Rear-seat heaters
Modern Luxury Package
- Rear-seat heaters
Sport Package with Polished-Finish Alloy Wheels
- Euro-tuned Sport Suspension
- 18-in polished-finish alloy wheels with P245/45R18 tires [15]
Sport Package with Chrome Wheels
- 18-in chrome wheels with P245/45R18 tires [15]
Individual Options
- SmartAccess
- Lexus Chrome Wheels (17-in or 18-in)
- All-season tires
- Wheel locks
- Car cover
- Trunk mat
- Ashtray kit
- XM Satellite Radio capability
Available Options:
- Headlamp washers
- SmartAccess
Cool box
Audio controls
- Headlamp washers
- SmartAccess
Cool box
Audio controls
- Headlamp washers
- Rear-seat heaters
- Headlamp washers
- Rear-seat heaters
Premium Package
- Rear-seat heaters
- Rear-seat heaters
Individual Options
- SmartAccess
- All-season tires
- Wheel locks
- Car cover
- Trunk mat
- Ashtray kit
The following 4 users liked this post by GRAND_LS 4:
iluvls460,
I understand you have a lot of question about the LS model, however, please do not start multiple threads for the same, or similar issue.
I have merged the threads together. Feel free to use the search feature to read through the wealth of knowledge this forum has to offer.
I apologize in advance for bumping a six-year old thread.
I found a document that explains the packages available in Canada for the 2003 LS430.
For example, up here, Headlight Washers and Park Assist were standard. The packages were 'Premium' and 'Ultra Premium', with the 'Ultra Premium' not having the cool box available. Might be worth adding to the first post. Additionally, it sounds like you could get the 'Premium Package' without Navigation.
Link: http://media.toyota.ca/pr/tci/en/lex...doc?ncid=13003
Content:
Lexus LS 430 Specifications & Features*
Dimensions
Body Type
4-door 5-passenger luxury sedan.
Construction
Unitized body with anti-vibration subframes. Extensive use of galvannealed steel and other anti-corrosive measures.
Overall Length
4995mm (196.7 in.)
Width
1830mm (72.0 in.)
Height (unloaded)
1490mm (58.7 in.)
Height (unloaded with air suspension)
1470mm (57.9 in.)
Wheelbase
2925mm (115.2 in.)
Curb Weight
1795 kg (3957 lb)
Tread (front/rear)
1570/1570 mm (61.8/61.8 in.)
Tread (front/rear with air suspension)
1575/1575 mm (62.0/62.0 in.)
Headroom (front/rear)
967/964 mm (38.1/38.0 in.)
Legroom (front/rear)
1118/954 mm (44.0/37.6 in.)
Shoulder Room (front/rear)
1481/1479 mm (58.3/58.2 in.)
Trunk Space
0.571 cu. m (20.2 cu. ft.)
Fuel Tank Capacity
84.0 L (18.5 imp. gal.)
Engine
Engine Type
(3UZ-FE) V8
Displacement
4.3 litres (4293 cc)
Valvetrain
DOHC 32 valves, Variable Valve Timing with intelligence (VVT-i)
Acoustic Control Induction System (ACIS) and Electronic Throttle Control System with intelligence (ETCS-i), Stainless Steel Exhaust System
Bore x Stroke
91.0 x 82.5 mm (3.58 x 3.25 in.)
Horsepower
290 hp (216 kW) @ 5600 rpm
Torque
320 lb. ft. (434 N.m) @ 3400 rpm
Compression Ratio
10.5:1
Engine Management
Computer control of sequential multi-point fuel injection.
Direct Ignition System (DIS) with dual knock sensors.
Fuel Requirement
Premium Unleaded recommended.
Ultra Low Emissions Vehicle (ULEV)
Drivetrain
Transmission
5-speed Super Electronically Controlled Transmission (Super ECT), Transmission Cooler, Overdrive top gear.
Drive Wheels
Rear-wheel drive with Traction Control system (TRAC)
Final Drive Ratio
3.266:1
Suspension
4-wheel independent, double wishbone suspension, coil springs, low pressure gas shock absorbers, and front and rear stabilizer bars. Anti-dive and anti-squat geometry, anti vibration subframes.
Steering
Vehicle-speed-sensing electronically-controlled Progressive Power Steering (PPS), power rack-and-pinion steering, 3.53 turns, lock-to-lock.
Brakes
4-wheel, power assisted, front and rear ventilated disc brakes.
Antilock Braking System (ABS)
4-sensor, 4-channel.
Brake Assist, Electronic Brake force Distribution (EBD)
Performance Capabilities
Acceleration, 0-60 mph**
6.3 seconds
Fuel Consumption, L/100 km***
12.8 City, 8.8 Highway, 11.0 Combined
Turning Circle
10.7 m (35.1 ft.)
Coefficient of Drag (cd.)
0.25 with air suspension
0.26 without air suspension
Exterior Features
Low reflection windshield with heating system and 3-jet washer nozzles
Integrated headlight washer
Helical-coil type short-pole antenna (mounted on the rear centre of the roof)
Wheels/Tires – 7-spoke 17x 7.5 JJ alloy wheels. P225/55R17 performance all-season radials (full-size spare tire).
Stainless steel exhaust system
Clearance and Back-up sonar
Interior Features
Leather package: Seats and headrests, armrest. Leather and wood steering wheel, shift **** and door trim.
Power-assisted driver and front passenger heated seats (Adjustments: 14-way driver, 10-way passenger). Headrest –vertical and tilt.
Lexus Driver Memory system includes three driver memory settings for power adjustments on driver’s seat, side mirrors, power tilt-and-telescopic, 4-spoke steering wheel and adjustable shoulder belt anchor
Maple or Walnut wood trim accents
Audio system: Lexus Premium AM/FM with cassette, 178-watt sound system with 7 speakers and Radio Data System (RDS)
In-dash 6-disc CD auto-changer, diversity, roof mounted antenna.
Electronic analog gauges with multi-function information
Display (Outside temperature gauge and Vehicle performance information)
Automatic air conditioning with dual zone climate control and manual override, independent driver and front passenger temperature soft-touch controls with dust, pollen and deodorizing air filter.
High solar energy absorbing tinted glass
Air quality control system: Exhaust gas and NOx sensors
Front centre console automatic swing register
Power trunk lid with auto close system
Rear window power sunshade
Power fuel filler door release
Power windows with driver and passenger “auto up/down” feature with jam protection
Power tilt-and-telescopic steering wheel
Power tilt-and-slide moonroof with sunshade
Dual heated power remote-controlled and colour-keyed side mirrors with electrochromic automatic dimming
Automatic dimming electrochromic day/night inside rearview mirror
Heavy duty rear window defogger with timer
Digital clock
Retained accessory power
HomeLink universal transceiver, integrated garage door opener
Upper and lower glove boxes
Convenience Features
Cruise control
Park assist
Adjustable rear seat headrests
Power driver and front passenger adjustable pillar shoulderbelt anchors
Front seatback pockets
Rear seat fold-down armrest/storage console with trunk pass-through access panel
Electronic compass in rearview mirror
Accessory power outlets
Driver and passenger illuminated vanity mirrors with ticket holder
Front and rear cupholders
Low washer fluid, engine oil level, fuel and coolant level, door ajar and pressure warning lamps
Power door locks with driver’s door 2-turn unlock feature
Map lamps
Reversible trunk mat
Two-level console box with sliding upper tray
Storage drawers under front seats, expandable front door pockets
Illuminated entry system
Carpeted floor mats
Cargo net
Automatic Light control system
Wheel-locks
Safety Features
Antilock Braking System (ABS) – 4-sensor, 4-channel.
Brake Assist
Traction Control (TRAC)
Vehicle Skid Control (VSC)
High Intensity Discharge (HID) headlamps with auto levelling system
Fully-integrated anti-theft deterrent system with encoded vehicle immobilizer
Driver and front passenger airbag Supplemental Restraint
System (SRS) with 2-stage deployment and occupant sensor on the driver and passenger side.
Side-impact airbag Supplemental Restraint System (SRS) for front seats
Window curtain airbags Supplemental Restraint System (SRS) front and rear
Front and rear outboard seatbelt pretensioner and force limiter system
Keyless remote entry with adjustable audible warning, trunk release and panic alarm
Variable intermittent wipers and rain sensing wipers
Integrated fog lamps
First aid kit
3-point rear seat centre lap and shoulderbelt
Full-size spare tire
Key lockout protection
Optional Equipment
LS 430 Premium Package includes:
“Standard Features” plus Mark Levinson Audio, 240-watt system with 9 speakers and Radio Data System (RDS). Perforated leather seat surfaces. Laminated side glass, front seat heater and A/C, Laser cruise control, Auto Door Closer. (LS 430 Premium Package also available with DVD-based GPS Navigation System).
LS 430 Ultra Premium Package includes:
“Standard Features” plus chrome alloy wheels, Mark Levinson Audio, 240-watt system with 9 speakers and Radio Data System (RDS). Air Suspension, laminated side glass, front seat heater and A/C, Laser Cruise, Auto Door Closer, sunshade on rear doors, rear A/C with climate control, rear power seats with massage setting, rear audio controls, DVD-based GPS Navigation System.
Available Accessories
Block heater
Warranty
Comprehensive coverage:
48 months/80,000 km (includes tires)
Powertrain: 72 months/110,000 km
Corrosion Perforation: 72 months/unlimited mileage
Roadside Assistance: 48 month, 24 hour roadside
assistance with free travel planning
Please see your Lexus dealer for details.
*TOYOTA CANADA INC. Every effort has been made to ensure the specifications and equipment shown are accurate based on information available at time of printing. In some cases, certain changes in standard equipment, options or product delays may occur, which would not be reflected in this brochure. Toyota Canada Inc. reserves the right to make these changes without notice or obligation. Your Lexus dealer is your best source for up-to-date information.
**Performance figure is shown for comparison only, and was obtained with prototype vehicles under test track conditions by professional drivers using special safety equipment and procedures. This should not be attempted on public streets or highways.
***FUEL CONSUMPTION RATING. These estimates are based on the Government of Canada’s approved criteria and testing methods, using 2002 model year vehicles. The actual fuel consumption of this vehicle may vary. Refer to the government of Canada publication – EnerGuide Fuel Consumption Guide.
Some features mentioned and/or shown in this brochure may only be available as part of an optional package.
Content:
Dimensions
Body Type
Construction
Overall Length
4995mm (196.7 in.)
Width
1830mm (72.0 in.)
Height (unloaded)
1490mm (58.7 in.)
1470mm (57.9 in.)
Wheelbase
2925mm (115.2 in.)
Curb Weight
1795 kg (3957 lb)
Tread (front/rear)
Trunk Space
Fuel Tank Capacity
Engine
Engine Type
(3UZ-FE) V8
Displacement
Valvetrain
Bore x Stroke
Horsepower
Torque
Compression Ratio
10.5:1
Engine Management
Fuel Requirement
Drivetrain
Transmission
Drive Wheels
Final Drive Ratio
3.266:1
Suspension
Steering
Brakes
6.3 seconds
Turning Circle
10.7 m (35.1 ft.)
Exterior Features
Interior Features
Digital clock
Cruise control
Park assist
Map lamps
Carpeted floor mats
Cargo net
Wheel-locks
Safety Features
Brake Assist
First aid kit
Optional Equipment
Block heater
Warranty
Content:
Dimensions
Body Type
Construction
Overall Length
4995mm (196.7 in.)
Width
1830mm (72.0 in.)
Height (unloaded)
1490mm (58.7 in.)
1470mm (57.9 in.)
Wheelbase
2925mm (115.2 in.)
Curb Weight
1795 kg (3957 lb)
Tread (front/rear)
Trunk Space
Fuel Tank Capacity
Engine
Engine Type
(3UZ-FE) V8
Displacement
Valvetrain
Bore x Stroke
Horsepower
Torque
Compression Ratio
10.5:1
Engine Management
Fuel Requirement
Drivetrain
Transmission
Drive Wheels
Final Drive Ratio
3.266:1
Suspension
Steering
Brakes
6.3 seconds
Turning Circle
10.7 m (35.1 ft.)
Exterior Features
Interior Features
Digital clock
Cruise control
Park assist
Map lamps
Carpeted floor mats
Cargo net
Wheel-locks
Safety Features
Brake Assist
First aid kit
Optional Equipment
Block heater
Warranty
Content:
Dimensions
Body Type
Construction
Overall Length
4995mm (196.7 in.)
Width
1830mm (72.0 in.)
Height (unloaded)
1490mm (58.7 in.)
1470mm (57.9 in.)
Wheelbase
2925mm (115.2 in.)
Curb Weight
1795 kg (3957 lb)
Tread (front/rear)
Trunk Space
Fuel Tank Capacity
Engine
Engine Type
(3UZ-FE) V8
Displacement
Valvetrain
Bore x Stroke
Horsepower
Torque
Compression Ratio
10.5:1
Engine Management
Fuel Requirement
Drivetrain
Transmission
Drive Wheels
Final Drive Ratio
3.266:1
Suspension
Steering
Brakes
6.3 seconds
Turning Circle
10.7 m (35.1 ft.)
Exterior Features
Interior Features
Digital clock
Cruise control
Park assist
Map lamps
Carpeted floor mats
Cargo net
Wheel-locks
Safety Features
Brake Assist
First aid kit
Optional Equipment
Block heater
Warranty
I found something in the display unit about park assist, where it monitors how close you are to the object in front and behind but I cant get it to work
What exactly is the park assist?
Parking sensors. Should beep when you get close to an object.
It beeps, shows a diagram on the dash display showing which area has triggered the sensors, and if you have nav, shows a similar diagram on the nav display. You will see four or so sensors on each of the front and rear bumpers. They are about the size of a quarter.
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I hope someone can help. I have just purchased a used 2005 LS430 with factory navigation. Everytime I get in the car the Navigation says "Blueetooth Not Connected"
I cannot find anywhere on the Navigation system to setup for the phone or Bluetooth. How can I get the system to recognize my phone?
Any suggestions?
I LOVE THIS CAR I would love it even more if the Bluetooth would work.
Any suggestions?
Any suggestions?
Any suggestions?
