How to programe the remote on 02 GS430
Old 02-25-08, 08:48 AM
derricklee
derricklee's Avatar
Smile How to programe the remote on 02 GS430
Is any body know how to programe a new remote on the 2002 GS430. I purchase a used remote on the ebay. Need instructions! Thanks
Old 02-25-08, 04:10 PM
TRD911
TRD911's Avatar
See this link.. I think this is what you want.
https://www.clublexus.com/forums/sho...ramming+remote
This should help.. my wife made fun and asked if she need to run around the car three times to get it to work.. ha ha ...
BP
Old 02-25-08, 10:18 PM
derricklee
derricklee's Avatar
I try this method two times. at the begining, everything like what he descripe. except the last step when i press the lock button. The door will not unlock. I guess this method will not fit my car.
Old 02-25-08, 11:48 PM
tnbigdawg
tnbigdawg's Avatar
Because those are the wrong instructions (similar, but different towards the end).
These are the correct instructions:
Remote Programming
1. Open driver door, keep it open and in the unlocked position (all other doors should be closed)
2. Put original key in ignition and pull out
3. Lock and Unlock the doors 5 times (complete each lock/unlock cycle within 1 second and
entire process in 40 seconds or less)
4. Close the door and open the door
5. Lock and Unlock the doors another 5 times (complete each lock/unlock cycle within 1 second and
6. Put the key in the ignition, turn it to "on" and then off (with 1 second) and remove from the ignition.
7. Press and hold transmitter LOCK and UNLOCK buttons simultaneously for at least 1.5 seconds,
and then within 3 seconds; press any transmitter button for at least one second.
8. If within 3 seconds, door locks cycle one time, new transmitter code was accepted. If door locks
cycle 2 times, new transmitter code was not accepted. If code was not accepted retry step 8 again.
Old 02-26-08, 12:27 AM
derricklee
derricklee's Avatar
wow.......this is right instruction! Thanks a lot. ^__^
Old 06-25-08, 04:48 PM
russian
russian's Avatar
Remote Programming
these instructions are wrong..
see here for proper instructions: https://www.clublexus.com/forums/sho...83&postcount=8
tnguyen89
12-13-15 11:30 AM
maxtcee
11-09-15 03:40 PM
JustaBowla
02-10-14 09:50 AM
vnguyen850
27
06-28-13 06:20 PM
LEXJG
10-26-11 04:27 PM
Quick Reply: How to programe the remote on 02 GS430
