Supercharged SC400 Vid
My 95 SC400 doing a 0-60 run in 5.07 seconds.
http://youtube.com/watch?v=nC7a-TpcSXc
In case you've missed my thread, go here.
https://www.clublexus.com/forums/sho...d.php?t=312268
There's also two more vids on post 169.
Thanks!
KC
Thanks!
KC
Hooray for Teal Mist Metallic. How's the power delivery feel with the supercharger? Does your engine fall on its face at higher rpm like the stock engine usually does?
My car runs fine as far as I know. I've never driven another SC400 though, so there's a chance she's not as strong as she could be. After about 5500 rpm, there seems to be a noticeable lack of acceleration compared to around 3500-4000 rpm.
When I'm on the highway (or @ 60mph + or -) and I very LIGHTLY touch the gas pedal, the car surges and jerks a bit, going lean. If I push just a little more, it goes away. This has been happening for a while, but it has recently gotten worse.
This is new. When stopped, if I gun the throttle a bit, it jerks two or three times, going lean and then takes off.
Also, while driving at any speed, if I gun the throttle it goes lean for like a milisecond, then is fine. I think the three problems are probably related.
I'm going into work a little bit later. I'm going to look up the TPS specs and adjust it accordingly. If that doen't work, I am going to UN bypass my fuel pump ECU. If that doesn't do anything, I'm going to blow out the MAF with air and clean the throttle body. If it's still not fixed, I'm going to leave it alone untill I get my new piping (should be here Tuesday) installed next weekend. I wouldn't be at all surprised if there is a leak in the piping somewhere causing the problem. I've even had leaks upstream of the MAF sensor that caused issues in the past.
KC
KC
