Changed My Fog Lights
To yellow bulbs by.....
Luminics JDM Yellow (9006)
![](http://us.st12.yimg.com/us.st.yimg.com/I/yhst-31825660550277_2026_61196860)
I like this look over the stock off white color, and have always like how the yellow w/ HID's looked on the GS & IS.
![](http://i8.photobucket.com/albums/a13/teehtf/100_1313.jpg)
![](http://i8.photobucket.com/albums/a13/teehtf/100_1312.jpg)
![](http://i8.photobucket.com/albums/a13/teehtf/100_1314.jpg)
![](http://i8.photobucket.com/albums/a13/teehtf/100_1315.jpg)
Far as the brightness, they are pretty bright! My camera setting may have something to do with it.
This thread http://www.clubcivic.com/board/showp...65&postcount=1 has pics of the yellow bulbs in action (much better than mine) and show they birghtness better. I can see that they are on while driving vs the stock ones.
I may go this route too with the yellow fog. I want it purely for function not for looks. Was it hard to swap out (can you reach from below or did you have to remove the wheel well plastic?).
Also, how much was the bulb? an eBay item?
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
nice man.i've got yellow fogs too.but they arent that bright.so i was gonna take one of the HID's from my GS and put them on the LS.i tried to remove the bulbs,but it wouldnt turn.was yours hard to turn?
-There are two little wrenches, use the bigger one and the bigger end to take the bolt screws off the under body panels on each corner of the car.
-Then reach up and twist the buld connector to unlock and remove the bulb.
-Depress the tab to release the bulb from the connector (Make sure you don't touch the bulbs with your fingers when swaping them out) then put the new bulb in tightly and reach up twist to lock into place.
-Repeat for the other side of the car, it's crazy easy!!!
Very easy to turn.
