IL F/S: 4-Pot Rotora BBK set up with Slotted Rotors! A Must see!!!
I already know the caliper is different from the GS300...I guess my point wasnt clear.
all I care about is the bracket and if its different. Rominl thinks they are not but I have no measurements or proof they are the same or different. From what I recall changing brakes on the front of an IS250 the points were not the same as my IS350. GS300 and IS250 share the same front caliper. IS350, GS350, GS430, GS460 all share the same front caliper...this is not new to me.
Thanks for the replies, I will get the data from Lexus to confirm the brackets are the same or different.
i didn't say whether i think gs300 is the same or not. i said i am not sure
also, is250 and gs350 have the exact same mounting points, i know for a fact because my brakes came from is250. and i am pretty sure is350 and is250 share the same mounting points too. gs300 and is250 sharing the same calipers design, but i don't know if they share the same bracket mounting point. if they do, then that means they are all the same. but like i said that's something i am not sure.
i hope my words are not tweaked otherwise anymore!
j/k
fyi if you need different brackets for a different car or different model lexus I confirmed they are only $165 with one of CL's vendors. Im not able to use them on my current car like I wanted to so its time to blow these out and be done. Ill take any serious offer to be done.
400DGRZ
08-10-10 12:52 PM
revspeed
13
07-10-08 07:53 PM
400DGRZ
06-15-07 09:27 AM
