MD 9005 led bulb 30w cree fog drl light bulbs
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
9005 LED BULB 30W CREE FOG DRL LIGHT BULBS with HID CANBUS FIX to use for DRL (see below for specifics). $15 + S/H.
Used in a 2006 Lexus GS300, worked perfectly as a DRL with the HID CANBUS FIX part and had to reverse the polarity (simple procedure and doesn't require any cutting of any wires) for my vehicle. Please check on the XenonDepot website if you plan to use for DRL. As a FOG light, this should work great as long as you have a 9005 plug. They are very bright and very white. They had very little use. Bought from XenonDepot, and paid around $60 with CANBUS cables. Like New. Switched out because as nice as they were as a bright white DRL light, LED's do not work as High Beams which I discovered I needed when I went to the mountains last year!
PRODUCT DETAILS
725 LM total output
Direct replacement for your 9005 / HB3 halogen bulbs
Full 360 degree all around emitting for maximum light output
Wide angle optical lens
5 watt high power CREE XB-R5 chips
Fits 9005 and HB3 fog light applications
Direct Replacement for your OEM 9005 halogen application. XenonDepot 9005 LED bulbs are manufactured from aircraft grade knurled aluminum parts and utilize 5W CREE LED diodes to provide the brightest possible output. Thanks to 360-degree all around emitting LEDs and wide angle optical lens, the XenonDepot 9005 LED bulbs provide more light on the road compared to any other HB3 LED bulb for your fog lights or DRLs. XenonDepot 9005 LED replacement bulbs are designed to work with any 9005 bulb for an easy installation. XenonDepot 9005 LED Fog light bulbs use the latest CREE XB-R5 LED diodes for maximum light output and durability. These 360-degree 9005 LED bulbs feature 5 CREE LED diodes to ensure you obtain broad and even light distribution. Unlike lower priced alternatives, CREE LED diodes are properly color matched to ensure proper color consistency throughout the LED bulb. Lower priced LED bulbs will provide you with less light output and uneven color matching meaning that your LED bulbs will appear to have a variance in color output. If you are upgrading a 9005 bulb that is currently used as a daytime running light you may need to purchase our canbus fix (included) so that you do not get any strobing/flickering with this bulb. These LED fog light bulbs are the ideal LED bulbs to better color match your HID low beam bulbs without upgrading your fog lights to HID with a XenonDepot HID kit.
Many newer vehicles that use canBUS technology require a component to modulate the power going to the ballasts to prevent this craziness from happening. XenonDepot's 9005/9006/9012 canBUS fix is a modular component that is designed to solve most of these situations, and get your 9005/9006/9012 HID kit working as it should. You can also use this component when upgrading your car's DRL to HID, but you may have to use this component in conjunction with a XenonDepot relay harness.
Please feel free to PM me with any questions.
PRODUCT DETAILS
725 LM total output
06-21-12 12:12 AM
