IL F/S: 4-Pot Rotora BBK set up with Slotted Rotors! A Must see!!!
for sale is a hardly used 4pot BBK set up, includes braided lines, 4 pot calipers, and slotted rotors. Locals I can help you install
PM me any questions for a quicker reply.
$1800.00
$1800.00
Im 90% certain the bracket is the same for the IS250 front/rear. Its the rotor that may be an issue due to the AWD. I recalled something being different but maybe I am wrong?
Im checking to see if this bracket would work on the front of the GS300/350/&430.
Its possible I may keep these and put them on a car Im getting for my son.
^you dont have a GS300?? I think they "may" work on the front of an IS250 or GS300 since they have the small factory front calipers.
I know the GS350, GS430, & GS460 have larger front brakes
It's not a matter of caliper size, it's where the mounting holes on the caliper are in relation to where it bolts up and positioning of the caliper
^ would you measure the IS300 and GS350 to see if they are the same? If I recall the IS300, IS250, and GS300 have the same front caliper.
Also I hope I can use these on my new toy with a new bracket. Just need to make sure the rotors will fit on the car once it arrives. If so these will stay with me and be put to use (crossing my fingers)
is250, is350, gs350, gs450h, gs430 (06+), gs460 as far as i know share the same bracket setup. brakes on my car came from is250. can't say about gs300 (06)
sc400, gs400, gs300 (01-05), gs430 (01-05), sc430, they share the same front brake setup
is300, it is another different front brake bracket setup from what i gathered
