Old 12-15-14, 04:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
How To: Replacing Side Mirror Puddle Lights w/ PICS!
Old 11-11-08, 12:17 AM
Eddiebx
Eddiebx's Avatar
Default How To: Replacing Side Mirror Puddle Lights w/ PICS!
I was thinking about posting this in the huge lighting mods thread, but figured it might be beneficial to make a new thread for easier searching in the future.
While I realize that yanking off the mirror is probably the easiest way to go about this procedure, I personally did not want to try that method after reading about some members cracking their mirrors when putting it back on.
The following is the method of swapping out the puddle lamps that I found to be the easiest and safest way. However results may vary, so please don’t be mad at me if you break something .
Step 1: Position the mirror as follows to expose the bottom outside screw.
Step 2: Use a long phillips head screw driver as follows to the loosen screw. (Note: It might help to stand up and apply pressure to the back of the mirror housing, so you can press the screw driver firmly to prevent stripping the screw head.)
Step 3: Position the mirror as follows to expose the top outside screw.
Step 4: Use a long phillips head screwdriver as follows to the loosen screw. (Note: It might help to stand up and apply pressure to the back of the mirror housing, so you can press the screw driver firmly to prevent stripping the screw head.)
Step 5: Now that you have both outside screws removed, use a plastic prying tool, such as a credit card to separate the housing halves slightly as shown below.
Step 6: Once the housing has been separated, maneuver the puddle lamp assembly out as follows.
Step: 7: Twist off the puddle lamp housing and replace the bulb with a 194 style bulb of your choice.
Step 8: Double check to make sure the bulb lights up properly before reassembling.
Step 9: Step back and enjoy the finished product!
Old 11-11-08, 12:39 AM
iKenn
Just call me "Sprinkes"
iKenn's Avatar
Thanks for the info.
Old 11-11-08, 12:50 AM
SeOuLiS250
SeOuLiS250's Avatar
or you can just yank out the mirror and unscrew all 4 screws
chris07is
chris07is's Avatar
ders a thread about this a long time ago...here it is...ask llamaboiz..the light LED guru
https://www.clublexus.com/forums/sho...ht=wedge+bulbs
Old 11-11-08, 01:00 AM
2slow
2slow's Avatar
This is on a 09 huh? Puddle light looks different. Great job with DIY, but there's already a thread on it. Maybe it can get combined.
Old 11-11-08, 01:13 AM
Eddiebx
Eddiebx's Avatar
this is actually on an 06 model, and I was aware of that original thread, however I didnt see any step by step pictures and thought it might be useful to some whom are still hesitant to pop the mirror off.
Feel free to merge this thread into the bigger lighting mod thread, I just thought it might be easier to leave a separate thread for searching purposes, instead of trying to sift through 30pages to find something.
Old 11-11-08, 01:42 AM
papaalex
papaalex's Avatar
Nice DIY Eddie, im one of the few cowards who has no ***** to yank out my side mirrors
Old 11-11-08, 01:47 AM
love67
love67's Avatar
how many led can it fits it?..can it fit in the V-LEDS 6 LED M-SMT??
Old 11-14-08, 11:54 PM
MRTUND350
MRTUND350's Avatar
I used the 4 LED High Power bulbs in mine, they are insanely bright!
How To: Replacing Side Mirror Puddle Lights w/ PICS!-img_5193.jpg
Old 11-14-08, 11:56 PM
MRTUND350
MRTUND350's Avatar
More pics:
How To: Replacing Side Mirror Puddle Lights w/ PICS!-img_5197.jpg
Old 11-14-08, 11:57 PM
MRTUND350
MRTUND350's Avatar
Ok last one:
How To: Replacing Side Mirror Puddle Lights w/ PICS!-img_5209.jpg
Old 11-15-08, 01:04 AM
crazybuggy
crazybuggy's Avatar
thanks! definitely lotta help
Old 11-15-08, 06:40 AM
iSuxeL
iSuxeL's Avatar
Hmm, I used a high power flank in mines and I wish it was brighter. Its so hard to tell how bright it is in pics. I've seen this write-up over at my.is, good write up, real easy
I second that, does anyone know if a 6LED would fit?
Old 11-15-08, 08:01 AM
gtmba
gtmba's Avatar
Great write-up, thanks!
Old 11-15-08, 02:08 PM
3KGT-IS350
3KGT-IS350's Avatar
I've been reading all these threads about changing puddle lamp bulbs and this one has the best directions! Thanks MRTUND350!
I was reading on another forum about changing the LED puddle lamps on an IS350 and there was several people that posted they had problems with the LEDs melting the lens and housing. They were using Ozium (I'm probably butchering the spelling) bulbs I think. Has anyone had problems with this?
The puddle lamps that are in an new gen limited Avalon is EXACTLY what I want. Are these bulbs compatible and where can I find them?
Quick Reply: How To: Replacing Side Mirror Puddle Lights w/ PICS!
