i need a drop... what springs should i get??
Old 05-02-09, 12:27 PM
panda_ek9
panda_ek9's Avatar
Default i need a drop... what springs should i get??
all i need is a drop.. i want atleast a 2' drop.. what springs should i get??
Old 05-02-09, 12:47 PM
Initial G
Initial G's Avatar
Eibachs or Tanabes might be what you're looking for. maybe Megans? F-Sports only provide a "mild" drop.
If you decide to change your mind, you can always go for a full coilover setup.
Old 05-02-09, 12:49 PM
Anthony
Anthony's Avatar
megan coilovers..
Or s-techs
Old 05-02-09, 01:34 PM
projectdna
projectdna's Avatar
s-techs are 1.6" up front and 1.2" in the rear.
road magnet springs will get you that 2" lowering.
anything lower, and you should look into coilovers.
Old 05-02-09, 01:51 PM
acefalcon2
acefalcon2's Avatar
if you want AT LEAST 2" you have to get coilovers... even roadmagnet does not really go down by 2
Old 05-02-09, 01:52 PM
four o two
four o two's Avatar
2 feet of drop will require at least a coilover system. I'd go with air though if you're looking to drop 2'.
Old 05-02-09, 02:58 PM
Coconut
Coconut's Avatar
The lowest drop you can get on springs would be either the H&R or road magnets and those would be around 1.6" and 1.2" rear.
If you want 2" drop your only choices are coilovers or air.
Old 05-02-09, 05:26 PM
badx33
badx33's Avatar
i dunno bro, i would go with coils over springs, but i heard that the tanabe's are good..
Old 05-02-09, 05:32 PM
BoOst3d
BoOst3d's Avatar
im dropped on Tanabe DF210 for a gs350. rear is tuckin tire and front has like a 1.5" gap between the fender and tire
these are 20s btw
Old 05-02-09, 06:54 PM
GiantsFan
GiantsFan's Avatar
This is javyLSU's car on H&R ...
Best drop for the 2IS IMO.... When I get springs ... its goning to H&R for me
Old 05-02-09, 07:20 PM
rob stolen
rob stolen's Avatar
I like the H&R!! BTW, how's your alignment, specifically camber in the rear with the H&R??
Old 05-02-09, 07:47 PM
GiantsFan
GiantsFan's Avatar
That's javyLSU's car. Im sure he can give you that info, just send him a PM.
and I agree, I love the look of H&R as well!!
Old 05-02-09, 07:58 PM
passnu2
passnu2's Avatar
I also think Javy was running a larger tire in the front, confirm that with him though im not postive.
Here are TeinS Techs on IS350...
front
rear
Was within factory spec after lowered and TOE was corrected.
Old 05-02-09, 11:21 PM
GiantsFan
GiantsFan's Avatar
^^ Yeah I believe he is on 19"s as well.
Old 05-03-09, 11:03 AM
happyhours
happyhours's Avatar
Anyone knows what brand and size of this rim?
Thanks
Quick Reply: i need a drop... what springs should i get??
