I would have to believe that if you went past the spot welds and then did a pull that you would have to have it re-welded (just like above). Once you go past those spot welds the structural integrity of the fenders has been jeopardized. Even if nothing happened right away, you should have a trusted bodyshop take a quick peak to make sure everything is okay.
whats the difference from shaving and cutting?? what tools are used to shave or cuttin?
To shave the fenders use a potato peeler to trim the fender lip away. It makes a nice smooth surface afterwards.
To cut the fenders use a pair of industrial strength scissors to cut the sheet metal, this doesn't leave as smooth a finish on the inside but goes a lot faster.
