DIY: 3GS Stereo Display Removal
Old 09-09-09, 01:32 PM
THE.K.W.C
THE.K.W.C's Avatar
Default DIY: 3GS Stereo Display Removal
Lexus 3G stereo display removal:
Note: This was done a 2006 GS300 AWD, but the removal should be the same for a 3G's.
Things you will need:
-Phillips screw driver
-10 mm socket / ratchet
-round edge panel popper
-about 15 min of time
STEP 1:
remove the shift ****. You will do this to remove the wood trim that covers the center console so you do not scuff it up.
STEP 2:
Use a panel popper to pop of the wood trim. DO NOT pry it up use a twisting motion so you don't crack the plastic, and start from a hidden spot just in case.
STEP 2.5:
Use a panel popper to remove the small thin plastic part right under the tape deck
STEP 3:
Put the car in Neutral !!!! MAKE SURE THE E-BRAKE IS ON!!!. Then move the wooden plastic trim over the shifter and disconnect the two (2) small plugs. These two (2) plugs go to the cig lighter and a small light FYI.
STEP 4:
You can now pu the car back in park. The center console in now wide open.
STEP 5:
You will need to remove the Leather side parts of the center console. These remove with a simple phillips screw on each side. There is a clip on the end of these leather parts closest to the rear of the car make sure you use a panel popper to pop them out. Once you undo the screw and pop the clips out a small amount of sliding force to the rear of the car will make them come loose
STEP 6:
Once the leather side covers are removed you can access the four (4) 10mm bolts that hold the display unit in place. There will be Two (2) bolts on the bottom right and left sides of the unit, and Two (2) 10mm bolts on the top right and left side as shown in the pictures.
Bottom Left
Top right ( I used a screw driver just to show you the hole)
STEP 7:
Once all 10mm bolts are out you will slide you hand under and behind the unit trying to pop the unit out. DO NOT USE A TON OF FORCE. You want to simply wiggle the unit out. Grab the unit a shake it back and forth in a controlled motion until it pops out.
STEP 8:
Once it comes loose your in the home stretch. CAREFULLY pull the unit out and unplug the clips and wires. Don't worry each plug only fits in one spot so as long as you plug them all back in your ok. I had a blue plug on the display unit that did NOT have anything plugged into it.
** ! BE CAREFUL NOT TO PUT THE SHIFTER ROD THROUGH THE SCREEN ! **
STEP 9:
Once pulled out, do as you wish. Add your dvd bypass, video input etc. To put it back together just repeat steps backwards.
Here are some pictures of the back of a 2006 GS300 display unit with
NO ML or NAVI. And the cavity behind the display unit.
Any other questions please let me know.
MODS!!! IF your reading this PLEASE PLEASE PLEASE sticky this. Way to many people ask the same question on how to remove this unit
-The.K.W.C-
Arussto (04-13-21)
Old 09-09-09, 01:35 PM
IXI187IXI
IXI187IXI's Avatar
nice write up. i believe there already is one on this though in the tips, tricks, diy thread.
Old 09-09-09, 01:55 PM
jtrue28
jtrue28's Avatar
where did you get that trim popper tool?
great write-up with pics!!
Old 09-09-09, 03:29 PM
THE.K.W.C
THE.K.W.C's Avatar
i got it when i used to do installs
Old 09-09-09, 06:53 PM
stvincent
stvincent's Avatar
i don't think i will have the guts to do that, but thx for sharing.
Old 09-09-09, 07:11 PM
yogregb
yogregb's Avatar
thanks for posting this ,great write up, I believe this is a little more detailed than the last one, all though it was good too
Old 09-09-09, 08:44 PM
vuiskool
vuiskool's Avatar
the 2nd day i got the car, i popped open onto the center wood trim is to get to my cig lighter to hardwire my V1. Was sweating because i was scared to scratch something. Ever since then, i didn't end up getting an ipod interface because im too chicken to open it back up.
And also because i don't want to welcome any rattles.
Old 11-03-09, 02:39 PM
jaguar_83
jaguar_83's Avatar
Thanks for the detailed pictures and instructions. I also have an 06' GS300 which I plan to install a MultiMediaLinQ from VIAS Tech so these DIY instructions will come in very handy!
Old 11-03-09, 06:28 PM
vladbph
vladbph's Avatar
http://www.youtube.com/watch?v=3uq69NfoddQ
Old 11-06-09, 12:23 AM
DrexLex
DrexLex's Avatar
Here's a PDF writeup from about 3 years ago. Nice for printing, but those pinhole cameras back then were just not up to snuff. The new pix in this thread are really nice!
Old 11-06-09, 12:26 AM
maying856
maying856's Avatar
Sweet write up, I wonder what the rear of a Navi w/ML looks like.........
Old 11-06-09, 06:57 AM
IXI187IXI
IXI187IXI's Avatar
i had mine opened up last year but i forget lol
its not really hard at all to pull the navi unit. takes make 10 mins.
Old 11-06-09, 09:28 AM
BinaryJay
BinaryJay's Avatar
I did this for my matrix to replace the rubbish standard GM radio that was in it, overall this looks like a lot more stuff to scratch and tabs to break than that job. I don't think I'll be doing anything like this so long as the rest of the car is in decent shape. :P
Old 11-06-09, 02:37 PM
DrexLex
DrexLex's Avatar
Pretty much the same. Why do you ask?
Old 02-28-12, 02:11 AM
leoking911
leoking911's Avatar
Thank you man, that's great stuff!
Quick Reply: DIY: 3GS Stereo Display Removal
