ZEE'S IS-F Exhausts
Former Vendor
ZEE'S IS-F Exhausts
ZEE'S has a great deal of experience with tuning Lexus cars and has produced an exhaust for the IS-F. However, instead of just providing one option, ZEE'S has chosen to make a few different versions of this exhaust, making anywhere from 15hp to 30hp. With that in mind I wanted to make an informative post about the various options.
ZEE'S calls their two exhausts version A and version B. Front, mid and rear sections are available separately for each version.
Version A uses the flanges below and the exhaust diameter goes from 60mm to 76mm to 70mm.
Version B uses the flanges below to increase the diameter to 76mm for the whole system.
Neither version is cheap, but it's hard to beat the quality and exclusivity of a system like this. You can see the dyno testing here.
-Patrick
-Patrick
Do you have any more information for us regarding this particular exhaust? What it's made of? Sounds clips? What advantages the differences in the flanges provide? Etc.
From the picture all it looks like is a secondary cat delete. Can you please give us some more information on the different versions. Dyno results and sound clips would be great.
Ya I saw this on the website, this whole system costs over 6k usd! But the quality and design is nice. The piping size is good too considering this V8 should be using 3" piping at least. I actually have a friend who is custom making a full Ti catback exhaust with a similiar design using 3-3.5 inch piping as well. It will be a while for it to show up as it's still in the R&D process. Anyhow nice exhaust system.
Former Vendor
Stock - 360.5ps
Type A rear section only - 374.4ps
Type A full exhaust - 382.4ps
Type B full exhaust - 389.3ps
According to the website the sound is more "exciting" than stock ("you can experience the race") However, they also say that it is not much louder. In fact, the rear section is supposed to be slightly quieter than stock.
-Patrick
After taking a look at this system im thinking about going straight pipes back to the muffler when headers hit the market Probably going to be way too loud though.
Received 1,063 Likes
It is my opinion that a Full Dual 3-3.5" exhaust system on an NA motor may not perform to well...
As Back pressure will be affected greatly.
But, it will be nice to see what happens during this R&D process..
Hopefully a few more ponies get squeezed out.
Also, one of the main reasons why we used 2.5" piping throughout our Full True Dual design, was spacing issues in some key areas.
Originally Posted by Lexus USA
The IS-F exhaust system starts with tubular exhaust manifolds and integrated catalysts. Next come dual 2.4 inch diameter front pipes that are joined before a pre-muffler and 2.7 inch single center pipe, after which the system splits into two 2.1 inch pipes and enter dual 16.8 liter mufflers.
Joe Z
Holy Cow... $6k ..
It is my opinion that a Full 3-3.5" system on an NA motor may not perform to well...
As Back pressure will be reduced greatly.
Joe Z
Joe Z
Yup over 6k usd for stainless steel too..that's JDM for ya. Anyhow ya 2.5 inch is a good size for a true dual system like yours but this isn't true dual, from header back into 1 single center pipe back out to the dual axle back so bigger piping might work. Who knows though, time will tell til someone tries it.
The Maker
subscribed. Another option to look at guys.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Tech Info Resource
Holy Cow... $6k ..
Joe Z
Joe Z
I'll be happy to discuss the physics of this, but the reality is most guys don't understand beans about pressure, volume, and exhaust flows; including many who claim to be tuners.
