93 SC300 AC/Heater control not working
Old 09-28-09, 08:31 PM
primo357
primo357's Avatar
Default 93 SC300 AC/Heater control not working
Hello all..haven't been here in awhile! Ah well, I lurked before :P Anyways, I have a question. The other day my AC/Heat controls stopped working in my sc300 (93). The backlight display is on, but none of the ***** or buttons work. It worked just minutes before...got out of the car, back in, and tried to turn on the air..nothing. Since there are no books for this model to reference...any ideas? Any help would be great as winter is approaching! Thanks in advance!!
Old 09-29-09, 07:14 PM
okbobbo
okbobbo's Avatar
Default Try here
https://www.clublexus.com/forums/per...t-working.html
Old 09-30-09, 08:53 AM
alanchad
alanchad's Avatar
Check for coin in cigarette lighter socket.
Alan
Old 10-04-09, 12:18 AM
primo357
primo357's Avatar
no coin (?).
Old 10-12-09, 04:40 PM
okbobbo
okbobbo's Avatar
Default Heater
This is the setup on the sc400. It may be the same on the ls400. Here is the actuator that has the rod on the bottom and the vaccuum switching valve that controls the actuator. Most of us have taken the vacuum hose off the VSV and connected it directly to the actuator which allows hot water full time to the heater box. Its not perfect, but the a/c works and so does the heater. The only thing wrong with this setup is that on just "air" it is warmed a bit.
Attached Thumbnails 93 SC300 AC/Heater control not working-img_1937-1-.jpg
Old 10-14-09, 10:09 PM
primo357
primo357's Avatar
I checked fuses and they are ok...even tried new climate control unit..same response - backlight works, but no lcd numbers showing (they aren't bled out either)..and no buttons/***** working...also just found out cig lighter isn't working either..but again fuses are all ok...suggestions?
Old 10-15-09, 06:29 AM
alanchad
alanchad's Avatar
The fuse info should be in your owner's manual if you have one.
According to my 92 sc400:
Fuse # 10(second row from top, fifth from the left) is for the cigarette lighter 15A.
Fuse # 11(next right) 7.5A
Under the hood, fuse # 23(fourth from left in string of about 10 fuses) 20A
I would check these three closely.
Hope this helps and good luck.
Alan
Old 11-11-09, 06:37 PM
primo357
primo357's Avatar
problem solved. thanks guys.
Old 11-12-09, 04:01 PM
okbobbo
okbobbo's Avatar
What was the problem?
Old 11-17-09, 12:23 AM
edwinbong
edwinbong's Avatar
my climate control is doing the same...any solutions? or troubleshoot tips?
Old 11-17-09, 01:41 PM
mike510
mike510's Avatar
i have the same problem too..any help or tips..
Old 12-25-09, 10:08 AM
SC300_NW
SC300_NW's Avatar
A coin got stuck in my cig lighter socket, which explains why my #10 fuse went out.
Old 01-13-10, 06:59 PM
2jzVIP
2jzVIP's Avatar
the same thing happened to me. I'd like to know your solution to this if you don't mind.
Old 01-14-10, 12:50 PM
bacaudio
bacaudio's Avatar
Come on tell us what your solution was.
Old 01-15-10, 09:44 AM
1uzDreamSC
1uzDreamSC's Avatar
if your cig lighter isn't working either then its your fuse for sure.
replace it even if its good and make sure its snug
it will work trust me
Quick Reply: 93 SC300 AC/Heater control not working
