F-Sport suspension and ridiculous camber and tire wear
I purchased a new IS350 that was loaded with all/every F-Sport items possible. Love the car, the way it looks and every detail but am SUPER pissed at one thing. Camber.
I dont understand how Lexus can sell a sport package suspension that has a negative camber of 1.5 degrees. I have only 13k miles on my car and wore through a set of tires due to the inside of them being worn away. Literally.
When I purchased the car no one told me the F-Sport suspension would put the car out of factory calibration settings. I received no disclaimer. In fact, I was told that its fully covered under Lexus warranty just like my regular parts on the car.
Suffice to say, I am pissed! I think its ludicrous to expect someone to swap tires every 15k miles or less due to a manufacturer defects in a suspension system they are selling as optional factory. There should be some type of camber kit included to make the suspension adjustable into factory spec!
I have sent Lexus a letter, filed a complaint with the BBB, and will continue to rant and rave until this is resolved. Even if that mans putting my factory stuff back on and refunding me the cost of this suspension. I just cannot believe I am spending $1200 on new tires and have only had the car 8 months!
Good luck with the BBB & Lexus. Lexus has clear disclaimers about the wear characteristics of "summer tires" and this is for the stock suspension settings.
[7] performance tires are expected to experience greater tire wear than conventional tires. Tire life may be substantially less than 20,000 miles, depending upon driving conditions.
I am well aware that summer tires wear faster than all season. That doesn't mean that the ENTIRE inside of all 4 wheels should be shredded and the remainder of the tire have plenty of life left. That denotes a serious suspension calibration issue. The middle and outside tread of the tires had at LEAST another 10k miles left if not more.
I don't think its a suspension defect...I was able to get 40k out of my stock tires and 15k of that was on h&r springs which is a lower drop than the sport suspension. I just recently got 19's to replace the stocks...I do think your problem is the tires...the advan sports only have 180 treadwear rating...the higher the tradwear rating the longer they last...pick some new tires that have 400+ treadwear, get an alignment and you will be happy...
Lexus does have a disclaimer saying its tires may last less than 20k miles, and that with STOCK suspension on tires/rims. Theirs also disclaimers on the F-Sport suspension parts stating that increased wear and harsher ride should be expected.
It is NOT a factory defect that the tires don't last that long. You upsize your rim, use lower profile SUMMER tires, lower your car and put on more responsive shocks and you expect your tires to last a long time? High performance oriented upgrades will increase wear and tear, plain and simple. You gotta pay to play.
The reason why the inside of your tires wear out sooner is because of too much toe, this is a well known issue. -1.5 camber should not affect tire wear that much.
yes, I agree that the tires will not last forever due to the type of car (performance) and tire type (summer performance) however when the complete inside of the tire is worn more than 50% more than the middle or outside, there is an issue. Period.
Toe has NOTHING to do with camber. That was a totally ignorant statement.
if you disagree, call your local performance suspension shop and ask them. I personally had GMG check my suspension. I doubt you get your cars serviced by such a reputable place.....
http://www.gmgracing.com/home.shtml
They confirmed, the suspension specs are way too far out of alignment thus causing the increased wear on the inside of the tires. They said that an adjustable camber kit SHOULD be included with this suspension, especially if it is considered a factory sponsored option.
My 2009 BMW M3 has 20k miles on it with larger, higher performance tires, and the wear is even and perfect. I drive that thing at the track on the weekend as well.......
Ok, I am getting frustrated. Im not sure how many cars you people have owned, or your prior experience with modifying vehicles.
I never claimed to be an alignment expert, I leave it to the pros at my shop.
