CT 200h Model (2011-2017)
Official Lexus UK PR: INTRODUCING THE LEXUS CT 200h
Old 02-26-10, 02:53 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
Exclamation Official Lexus UK PR: INTRODUCING THE LEXUS CT 200h
February 26, 2010
KEY POINTS
  • Lexus’s first premium compact model
  • Lexus Hybrid Drive powertrain with 1.8-litre VVT-i petrol engine and powerful but compact electric motor
  • Full hybrid system with selectable EV mode for emissions-free electric running
  • Further selectable ECO, NORMAL and SPORT driving modes
  • ECVT intelligent electronic continuously variable transmission
  • Expected to deliver class-leading CO2 emissions
  • Significantly lower NOx emissions than equivalent diesel engines and almost no particulates
  • Long, 2,600mm wheelbase ensures excellent accommodation for everyone on board
  • Debut at Geneva motor show prior to worldwide sales launch in late 2010
The new Lexus CT 200h is the first full hybrid vehicle to be launched in the premium compact segment. Entering production in late 2010 and set for sale worldwide, the full hybrid model will provide a new gateway to the Lexus range and attract new, younger customers to the brand.
The CT 200h was designed and developed with the European market in mind. Lexus’s first five-door compact car, its size, packaging, full hybrid technology and low emissions fully address the requirements of discerning, environment-conscious customers in a key market sector. At the same time, it does not compromise the quality, refinement and driving pleasure that are the hallmarks of every Lexus.
Exterior and interior design
The production-ready CT 200h retains strong visual links to the LF-Ch concept Lexus unveiled at the 2009 Frankfurt motor show. Its styling marks a powerful evolution of Lexus’s L-finesse design philosophy with a distinctive, sharp-edged look that sets it apart from its premium compact rivals.
The exterior is styled for maximum aerodynamic efficiency and minimum wind noise. The strong front grille, directly referencing the LF-Ch concept sits over a full-width bumper and air dam. The headlamp units, positioned higher than the grille (a signature feature of L-finesse design), incorporate LED daytime running lights.
In profile, the steeply raked windscreen, long, flowing roofline and Lexus slingshot window graphic combine to create an elegant and distinctive silhouette. The front and rear corners have been pulled in tight and the wings are styled to improve airflow down the sides of the vehicle.
At the rear, the trailing edge of the roof overhangs a wide, wraparound rear window to create a seamless, integrated spoiler. A pronounced step in the tailgate section flows from the shoulders of the rear wheelarches and is anchored by a tail lamp design that displays the L-shaped motif that Lexus first introduced on the current LS model.
The interior combines superior ergonomics with extensive use of metallic finishes and dark, soft-touch surfaces.
Lexus has retained the asymmetrical dashboard design seen in the LF-Ch show car. Based on the Future Lexus Interior concept, the dashboard is split into an upper Display Zone, with an eight-inch LCD multi-display screen; and a lower Operation Zone, with the shift lever and other controls such as Lexus’s Remote Touch multi-function controller.
In keeping with the car’s performance, the driving position is set low, with a highly supportive driver’s seat. The instrument binnacle houses large, twin dials; in SPORT mode, the hybrid indicator in the binnacle functions as a tachometer and the ambient lighting turns from blue to red. The two-mode switch ring and a spotlight in the centre cluster also light up in red, changing the whole atmosphere of the cabin.
In spite of its compact, efficient design, the CT 200h offers a roomy interior. The 2,600mm wheelbase allows for front and rear passenger accommodation that is among the most spacious in the segment. Luggage capacity is 345 litres, increasing to 700 litres with the rear seats lowered.
Lexus Hybrid Drive
The Lexus Hybrid Drive system in the CT 200h combines a 1.8-litre VVT-i petrol engine with a powerful electric motor. Drivers have the choice of four selectable drive modes: ECO and NORMAL place the emphasis on efficiency and comfort, while SPORT focuses on dynamic performance.
Unlike mild hybrid systems used by other manufacturers, the CT 200h also has an EV (electric vehicle) mode that allows for ultra-quiet running on the electric motor alone, resulting in zero fuel consumption and CO2, NOx and particulate emissions. The car is capable of running in EV mode for up to 1.2 miles at speeds up to 28mph.
Chassis and suspension
The CT 200h is built on a new platform with a dedicated double wishbone and trailing arm rear suspension system. It has been developed specifically to combine the ride comfort expected of a Lexus with superior driving involvement and handling agility.
Several elements in the MacPherson strut design have been exclusively developed for the mode, including the coil springs and shock absorbers, and a new front anti-roll bar has been designed to deliver improved roll rigidity.
The double wishbone rear suspension is exclusive to the CT 200h and incorporates a lightweight trailing arm. The springs and shocks are positioned separately to minimise intrusion into the loadspace floor.
[B]Lexus CT 200h outline technical specifications
Code:
LEXUS HYBRID DRIVE
ENGINE
Number of cylinders
4, in-line
Displacement (cc)
1,800
MOTOR GENERATOR
Motor type
Permanent magnet synchronous motor
HIGH-VOLTAGE BATTERY
Battery type
Nickel-metal hydride (NiMh)
TRANSMISSION
Type
Front-wheel drive
Gearbox type
Electrically controlled continuously variable transmission (E-CVT)
SUSPENSION
Front
MacPherson strut with anti-roll bar, coil springs and shock absorbers
Rear
Double wishbone with coil springs and shock absorbers
STEERING
Type
Electric power-assisted rack and pinion
EXTERIOR DIMENSIONS
Overall length (mm)
4,320
Overall width (mm)
1,765
Overall height (mm)
1,430
Wheelbase (mm)
2,600
Front track (mm)
1,525
Rear track (mm)
1,525
Front overhang (mm)
915
Rear overhang (mm)
805
WHEELS
Type/size
Alloy, 17in
LUGGAGE CAPACITY
Rear seat up (l, VDA)
345
Rear seat down (l, VDA)
700
Credit: Lexus UK
Old 02-26-10, 02:56 AM
flipside909
Lexus Connoisseur
Old 02-26-10, 02:57 AM
flipside909
Lexus Connoisseur
Old 02-26-10, 02:58 AM
flipside909
Lexus Connoisseur
flipside909
Lexus Connoisseur
[img]http:
Old 02-26-10, 02:59 AM
flipside909
Lexus Connoisseur
//www.lexusgb-press.co.uk/protected/releases/2010/59898-l-lex-.jpg[/img]
Photo Credit: Lexus UK
Old 02-26-10, 03:14 AM
whoster
whoster's Avatar
erm, Ryan I think you posted the same set of pictures twice.
otherwise, damn I'm loving this car.
Old 02-26-10, 04:04 AM
dunnojack
dunnojack's Avatar
the bad thing about this car is- if you take the badge off, you can't really tell it's a lexus.
not much different from mazda
Old 02-26-10, 05:36 AM
JessePS
JessePS's Avatar
If the CTh does come to Canada I wonder if they will make it AWD or it will only be FWD I don't mind FWD I find its really good in winter.
Old 02-26-10, 05:44 AM
spwolf
spwolf's Avatar
Thing to note - there is no trunk space lost here... car has 340 liters of trunk, more than 1 series and slightly less than A3 (10l)...
Old 02-26-10, 05:52 AM
TripleL
No Substitute
TripleL's Avatar
I like what I see inside and out.
If it were in the US the only thing that would stop me from making it a daily driver would be AWD which I'm not expecting to be added given the purpose/goal of this fine vehicle.
Old 02-26-10, 06:15 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Those seats look great.
Old 02-26-10, 06:18 AM
LexFather
Guest
Posts: n/a
Thumbs down
(looks at sig smh)
Old 02-26-10, 06:52 AM
SLegacy99
SLegacy99's Avatar
I like it. And I suppose that it does make sense to have an efficient model that isn't focused on acceleration numbers. However, it would be nice if they were to set the powertrain apart from the Prius with something like direct injection. Presumably a Lexus buyer is going to pay more anyway right?
Old 02-26-10, 06:58 AM
Allen K
-0----0-
Allen K's Avatar
Adding a bit more to the engine would be nice but the overall improved build quality will probably be what makes this more expensive than the Prius.
Being "set for sale worldwide" makes me happy
Quick Reply: Official Lexus UK PR: INTRODUCING THE LEXUS CT 200h
