Can I run with ECT Power mode continuosly?
i do and i actually notice about 1-2 more mpg with ectpwr on all the time. i do prob half and half for city and hwy driving.
iv also noticed with the pwr mode while on the hwy and i go to slow down the car will auto downshift and use the lower gears rpms to slow me down
i use it all the time when im in city traffic. just being able to respond a little quicker to cut through traffic when needed. on the highway though i prefer ect off. but to answer your question, yes i use ect QUITE frequently
UnkleLex (09-25-23)
there's a writeup on supraforums, by Raven77099 or something like that. The guy's name is Jared, and he's really tino the A340s. He's the one who shows how to do the valve shim mod, and he's the one (among others) that have said ALWAYS PWR mode.
Normal if for "slow soft shifts" for people who think PWR it too harsh. The less you feel the transmission, the more it has to work for you to feel less, the more you feel, the less the transmission has to work. Hence shift kits.
Jeff
Jeff
do you have the 250?
I notice a difference when I'm cruising along and when I hit the throttle to pass someone or just to accelerate, the ecu will force the tranny to downshift a gear or two instead of keeping it in the same gear and accelerate in the gear I am in unless I mash it to the floor of course.
Throttle response is better at part throttle. Full throttle is the same though.
Hmm, this is an interesting thread. This makes me want to run power all the time lol. I miss the downshifts when coming to a stop. If you don't feel the difference with power then you're probably in manual shift mode. I made that mistake, but once in full auto mode you feel it.
Does this mean that snow mode is bad for your transmission in the long run? I actually control my max gear a lot to cut down on excess shifts (ie 6th gear while going 35mph, when i rather stay in 4th), am I hurting or prolonging the transmission this way?
EDIT: Read up on ravens shim mod, seems like faster/harder shifting = longer transmission life which would correlate with using pwr mode. I couldn't find anything specifically saying that you should run power though.
