Suspension Torque Specs - Bushing Reset Info **LOOK HERE FIRST**
Old 07-30-09, 08:44 AM
leftyjohn
leftyjohn's Avatar
Default Suspension Torque Specs - Bushing Reset Info **LOOK HERE FIRST**
Hi---did a search and couldnt find anything. Would someone please list suspension torque specs Much appreciated-------------LJ.
Someone was kind enuf to send me specs. So no assistance needed anymore. Thanks
Popular Reply
04-30-10, 08:43 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,010 Likes on 2,429 Posts
This diagram has everything you need for the front:
This diagram has everything for the rear:
EDIT - The Rear Upper Control Arm No. 2 ball joint end should never be loosened. It does not impact ride height or bushing life in any way. The only reason to remove that nut is if you are replacing the control arm. That nut is the only "non-reusable" part in the diagram and again, is never loosened or removed unless you are replacing the entire arm.
Old 04-30-10, 08:43 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
The following 11 users liked this post by lobuxracer:
autovation (07-01-19), bryceis250 (02-20-19), Classy97 (04-03-23), isfvss (04-19-17), Rickna (05-16-17), s0ar (12-08-22), SCJim (07-30-19), strikeraj (12-14-17), TheUser (08-17-21), true (12-26-23), WillAP1 (04-24-19) and 6 others liked this post. (Show less...)
Old 05-26-10, 07:52 PM
llhelix
llhelix's Avatar
So I've got a question. It's concerning the torque spec for the nut/bolt closer to the center of the vehicle on the lower control arm. In Lobux's rear figure, it's labeled "140 (1,430,103)." If anyone has a copy of the F-Sport springs or shocks installation guide, the reassembly notes to retorque the nut to 75 ft-lbs, but if using a SST it needs to be set to 103 ft-lbs. So in Lobux's figure, is the 103 ft-lbs assuming you use the SST (basically a torque adapter)? Or is it supposed to be 103 ft-lbs without a torque adapter? I'm concerned because I currently have it at the 75 ft-lbs stated in the installation instructions, but here it says otherwise. (I'll scan a copy of the instructions when I get home later). I wouldn't mind just torquing it to 103 ft-lbs but without knowing the bolt's rating, I can't be sure 103 ft-lbs won't snap it. Anyone know for sure?
Old 05-27-10, 11:15 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
It's the opposite. Here's what TIS says:
(d) Using a ball joint lock nut wrench (19 mm), fully tighten the nut (D) on the rear suspension member side.
Torque: 140 N·m (1,430 kgf·cm, 103ft·lbf)
When using a ball joint lock nut wrench - Torque: 102 N·m (1,040 kgf·cm, 75ft·lbf)
So with the SST it's 75 lbf, without it, it's 103 lbf. Any time you add length to a torque wrench the numbers get smaller, not bigger.
Important to note also - many of the nuts are semi-captive. TIS says (contrary to standard practice in fastener tightening) to tighten from the bolt side. Do NOT tighten the nut, it will not work correctly. It should be obvious if you try to do this wrong, but I'm stating it here just to be crystal clear.
Old 05-27-10, 11:31 AM
llhelix
llhelix's Avatar
Great, thanks lobux for the info!
Old 09-22-10, 09:35 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
This seems to be a recurring subject, so I've stickied it. Please look here first!
The following 2 users liked this post by lobuxracer:
bryceis250 (02-20-19), SCJim (07-30-19)
Old 09-22-10, 11:40 PM
MyIS350G
MyIS350G's Avatar
I guess what my question was that how do you reset the bushing? I see the diagram but what bushing are we talking about here?
thanks
Old 09-23-10, 01:54 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
thanks
Loosen all the bolts shown in red in the diagram. The FSM says bounce the car a few times on each corner, then tighten all the bolts to the specified torque. This sets the bushings at a neutral position when the car is at normal ride height and minimizes the stress on them when loaded.
I cheat a little. I put the car on four jackstands, loosen the bolts on the corner I want to reset, put a jack under the knuckle and raise it until the corner just starts to come off the jackstand. I give it a little bounce, then I tighten the bolts on the corner I'm resetting. Move to the next corner and repeat until all four are done.
When you lower a car and fail to do this, the bushings are stressed at their normal ride height, and extra stressed when the car is loaded. This softens the bushing more rapidly because it is deflecting more than it should be. It can also lead to premature bushing failure, but it won't happen quickly.
Old 09-23-10, 04:24 PM
MyIS350G
MyIS350G's Avatar
Thank you! Now I finally understand.
Old 08-22-11, 01:08 PM
TheSenator
TheSenator's Avatar
speed sensor is 53 INCH/lbs = 4.416666 ft/lbs
Old 09-13-11, 12:32 AM
freeflight
freeflight's Avatar
Good to know.
Old 11-10-11, 11:38 AM
XhyDra
XhyDra's Avatar
Lance, by any chance do you have the torque specs for the front caliper bolts and front hub bolts that hold it to the knucle. Thank you
Edit: Nevermind got them already, 51ft lbs for the hub bolts and 58ft lbs for the caliper bolts.
Old 01-18-12, 10:24 AM
Boofster
Boofster's Avatar
FYI rear toe link specs:
Rear toe taper stud: 70 N·m (714 kgf·cm, 52 ft·lbf)
Rear Eccentric bolt: 50 N·m (510 kgf·cm, 37 ft·lbf)
The following 2 users liked this post by Boofster:
Old 04-16-12, 09:57 AM
JCat27
JCat27's Avatar
good to know, this will be helpful with my coilover install
Old 04-19-12, 08:50 AM
reyoasian
reyoasian's Avatar
is it standard install procedure to reset bushing? and how soon to align? im getting my h&r springs installed soon and it would be nice toknow about this beforehand so I know what the installer is supposed to do and not do.thx!
Quick Reply: Suspension Torque Specs - Bushing Reset Info **LOOK HERE FIRST**
