04 lexus ls 430 telescopic steering column
Old 01-12-10, 06:19 PM
jcaballe
jcaballe's Avatar
Default 04 lexus ls 430 telescopic steering column
I have an 04 430 ls and the telescopic steering column is not working will not move up or down nor in and out? I checked the fuses and they are good, any ideas??
Old 01-12-10, 06:42 PM
DDLexus
DDLexus's Avatar
There are several fuse locations. Just make sure you check them all. Should be referenced in your owners manual.
No. FUSE AMPERE CIRCUIT
1 TI & TE 20 Tilt and telescopic steering
or
19 IG2 30 SRS airbag system, Engine immobilizer system, Steering lock system, Starting system
or
24 MPX-B3 7.5 Tilt and telescopic steering, Headlight switch, Windshield wiper and washer switch, Turn signal switch
Old 01-12-10, 06:48 PM
jcaballe
jcaballe's Avatar
I cheked the three fuses but all of them are fine!! is there a feature that may me blocking that remote or button??
Old 01-12-10, 07:21 PM
dan812
dan812's Avatar
If the wheel does not move when you start the car with or wothout the key (smartkey) and all fuses are good - I would bet the motor failed. Try using the driver seat memory functions and see if the steering wheel moves since it would be stored in memory.
Old 01-12-10, 07:38 PM
jcaballe
jcaballe's Avatar
I went and checked everything again and one of the fuses was not all the way in and thank god it worked!! I appreciate your time and knowledge for sharing it with me. I just bought this car for my wife and not used to this type of cars. Have you heard of the navigation screen going black after several minutes of driving the car?? they tell me that i need to get a new multi display navigations screen. What do you think because it's very expensive!! runs about $1,900.00 in exchange. Is there a company out there that might refurbish this screen?? other people say it might be the ecu???
Old 12-13-10, 07:09 AM
Intune
Intune's Avatar
or
or
Hate to revive an old thread but my 01 is doing almost the same thing but it does go in & out. Just not up & down. Could it still be a fuse? Thanks!
Old 12-13-10, 08:26 AM
DDLexus
DDLexus's Avatar
most likely the problem is with the tilt motor. If you're handy, you can access the tilt motor and check to make sure it is getting current. Replacing that motor isn't too hard. It's close to the front of the steering rack. I'll post a pic in a few minutes.
Old 12-13-10, 08:39 AM
DDLexus
DDLexus's Avatar
Images of tilt motor location.
Attached Thumbnails 04 lexus ls 430 telescopic steering column-tilt-motor_image1.jpg   04 lexus ls 430 telescopic steering column-tilt-motor_image2.jpg
slyder
03-30-19 06:38 PM
jrw100
09-01-13 08:13 PM
hksnlper
09-19-07 01:04 PM
rloebclublexus
Maintenance
01-31-04 01:25 PM
Quick Reply: 04 lexus ls 430 telescopic steering column
