'99 rx 300 sun visors
howdy-
wife's '99 RX has a loose left-side of course sun visor that deploys over bumps. handy if you're driving into the sun; not handy if it's dark out.
dealer wants 500 to replace, and i've tried several methods to tighten-up the roll-pin. no soap. any thoughts?
Welcome to ClubLexus!
This has happened to others too. If you use the search function, I think you will find that some have inserted a piece of sandpaper to give more friction, as I recall. That's one approach, I remember correctly.
Hmmm. I must have seen it here because this is just about the only forum I read. I'm still looking, but I did find this thread from 2005, entitled "How to tighten the sun visor?".
There is no adjustment. Replacement is the correct fix.
velcro is what I plan to do for mine.
Salim
Salim
tried the 'search' but didn't find anything? I know replacement is the proper fix, but $500.
I'll try the sand paper fix, have also considered velcro to hold it up but am not sure how it would adhere to the fabric in time.
I tried wedging some 8 penny coated nails into the visor at the hinge point to no avail. thought about super glue, but chickened out. I'll try the samd paper and keep you posted. have to do something;wife is on it!
thanks for the discussion.
Jag. I have the same problem but on the passenger side, so the replacement cost is less as the home link is not there. I would not pay labor to fix it as it is can be done by any one who can handle a screwdriver *dealer charge of 1/2 hr labor $50+)
Try searching the term "visor". I am too lazy to do it for you and post it here, but the only fix seems to be is stuff things along the metal rod.
I have also contemplated a small magnet and a pin (magnet glued to the visor side). Also check on ebay.
Salim
Salim
$187.50 at http://www.lexuspartsworld.com
Replace it - nothing else works (with the possible exception of the Velcro). Pop off the plastic cover on the shaft mount on the headliner, unscrew the mount and pull out the visor, unplug it from the harness in the roof cavity. 5 minutes, tops!
Installation is the reverse.
keith, the price is $704? WTF!!! how can it go up so much?
http://www.lexuspartsworld.com/Scrip...?idproduct=262
I am trying this:
I purchased some Hillman plastic Push Fasteners from Lowes. I cut Velcro in a circle and stuck it to the top of the fasteners. Then, I drilled a 5/32 hole in the visor where I could see it would come closest to the headliner. Then, pushed the fastener into the hole. I then stuck the remaining fastener (inverted) on the installed fastener and pushed the visor up to mark the hole for the headliner. Then, drilled the headliner 5/32 hole at the mark and pushed the fastener up into it.
Both fasteners work perfectly and are stuck securely in their holes. The high quality Velcro seems to hold. We'll see how it works over time. Will report back.
Pic of the plastic fasteners--part number on bag (Lowe's):
Velcro for plastics, drill bit:
![](http://img703.imageshack.us/img703/3758/img0983.jpg)
Finished Visor:
![](http://img337.imageshack.us/img337/5827/img0982gk.jpg)
Finished Visor:
![](http://img98.imageshack.us/img98/2960/img0985t.jpg)
http://www.mrmikes.com/fieroquestions.htm#visors
Checkout this page it is for the fiero but will help as similar setup.
Other idea is get rid of the visors and add some LCD screen visors
http://cgi.ebay.com/ebaymotors/PAIR-...ht_3358wt_1002
$135 a pair + delivery.
