Aftermarket Wheel Owners Post Your Setup
Trying to compile a list of aftermarket setups so a range of wheel sizes & offsets, tire widths, to reduce speedo error, avoid rubbing, maximize looks/performance, etc. Hopefully, to make a quality reference thread.
Stock information:
16" RWD (Canada/non-USA Only):
Front and Rear: 205/55R16, 16x7 +45mm
17" RWD:
Front: 225/45R17, 17x8 +45mm
Rear: 245/45R17, 17x8, +45mm
17" AWD:
Front and Rear: 225/45R17, 17x8, +45mm
18" RWD :
Front: 225/40R18, 18x8, +45mm
Rear: 255/40R18, 18x8.5, +50mm
Use tire calculator to find tire size closest to original overall diameter, afterwards check if desired tire model & size are available using www.tirerack.com or equivalent site:
http://gs.tolan-hoechst.com/tirecalc.htm
Please fill in the following aftermarket information:
Lexus IS model:
Wheel Make & Model:
Wheel Size (diameter and width):
Wheel Offset Front:
Wheel Offset Rear:
Compatible with tire pressure sensors?
Tire Make and Model:
Tire Size Front:
Tire Size Rear:
Suspension mods:
Amount of drop:
Description of wheel gap, fender flushness, rubbing, aesthetics, compatibility with tire pressure sensors, and other comments and problems if any (clear pictures to support description would help greatly):
PM me with corrections if you discover errors
Stock information:
17" RWD:
17" AWD:
18" RWD :
Lexus IS model:
Wheel Make & Model:
Wheel Offset Front:
Wheel Offset Rear:
Tire Size Front:
Tire Size Rear:
Suspension mods:
Amount of drop:
OrthoMT (06-05-18)
Lexus IS model: IS350 Luxury Package
Wheel Make & Model: Rays Lexion 203
Wheel Size (diameter and width): 19x8.5 &19x10
Wheel Offset Front: +38
Wheel Offset Rear: +45
Tire Make and Model: Toyo T1R
Tire Size Front: 245-35-19
Tire Size Rear: 275-35-19
Suspension mods: Stock Suspension
Problems: Front tires rub when turning.
I too had the rubbing against the plastic tab behind the front wheels closest to the driver and passenger even before and after I put aftermarket wheels and tires.
Here is a pic of the area that is rub, I fixed the problem using a heatgun to heat that plastic area and used a clean tower to push it against the fender.
the rubbing got nothing to do with the offset or dropping the car because it's rubbing on the side of the wheelwell, just the overall diametter of the tires that make it rub when you turn the car. Just go to the car, have someone turning the wheel for you and take a close look at the gap behind front wheel and the the fender liner. It gets real small when you turn.
tire width would contribute to this type of rubbing I would think. Slap on a wider tire now the wider tire is swinging around in a larger radius and getting close to the wheel well splash guards like above
what I think about rubbing so far:
fender rubbing = bad offset, suspension drop, tire size combination
wheel well rub = bad tire size
i know there are more people than this with aftermarket wheels, i need their setup info then we can avoid fitment issues like this by finding out which offset, tire size, suspension combinations work and dont work and avoid repeat threads of "will this fit" "will this rub" etc
Judging from the number of views this post has, I would think people would be extremely interested in this information. I just need more of it
speshul c
Lexus IS model: 250 AWD
Wheel Make & Model: Zenetti Fives
Wheel Offset Front: Hi (38 i think)
Wheel Offset Rear: Hi (38 i think)
Tire Make and Model: Toyo Proxes
Tire Size Front: 235/35/19
Tire Size Rear: 235/35/19
Suspension mods: tanabe nf210s for the is350
Amount of drop: .8 front 1.0 rear
![](https://www.clublexus.com/gallery/data/3560/medium/063006_008.jpg)
hfbldpnce (01-31-21)
IS350
Volk SF Challenge Diamond Black
F - 19x8.5 offset +34mm
R - 19x9.5 offset +40mm
Toyo Proxes T1-R
F - 235/35/19
R - 275/30/19
No suspension mods
Wheel gap about the same as stock, wheels flush with fender, very slight rub when turning at a 45 degree angle in reverse. No rub moving forward or when reversing at a very slow pace.
![](http://i1.tinypic.com/o0pjrk.jpg)
![](http://i1.tinypic.com/o0pibp.jpg)
Toyo Proxes T1-R
F - 235/35/19
R - 275/30/19
No suspension mods
![](http://i1.tinypic.com/o0phz9.jpg)
https://www.clublexus.com/forums/sho...2&page=1&pp=15
IS350
Zenetti Five
F - 20x8.5 offset +40mm
R - 20x10 offset +43mm
Nitto 555
F - 235/35/20
R - 275/30/20
No drop
![](https://www.clublexus.com/gallery/data/3484/medium/3.JPG)
![](https://www.clublexus.com/gallery/data/3484/medium/4.JPG)
edit: added more pics from this thread:
https://www.clublexus.com/forums/sho...d.php?t=204511
![](https://www.clublexus.com/gallery/data/3524/medium/DSC01002.JPG)
![](https://www.clublexus.com/gallery/data/3524/medium/DSC00992.JPG)
![](https://www.clublexus.com/gallery/data/3524/medium/DSC00998.JPG)
IS350
Zenetti Five
Nitto 555
F - 235/35/20
R - 275/30/20
No drop
I notice that i have a lil rub inside the front wheelwell when i make a hard turn. I was aware of that problem thou. I wanted +38 offset but they only have +40 on that rims. Plus i rather have a lil rub on the inside than having rub on the outside of the fender and wheels sticking out. These rims i plan to have it for a year or two just to test with the car being drop soon. Later i'll get a nice perfect one for this car.
Last edited by javyLSU; 06-27-07 at 10:32 PM. Reason: rearranged pictures for ease of viewing
Originally Posted by 4TehNguyen
Stock information:
17" RWD:
Front: 225/45/17, 17x8 +45mm
Rear: 245/45/17, 17x8, +45mm
17" AWD:
Front and Rear: 225/45/17, 17x8, +45mm
17" RWD:
17" AWD:
Original Thread:
https://www.clublexus.com/forums/sho...91#post1750591
IS350
ADR Sterling Staggered
F - 20x8.5 offset +35mm
R - 20x9.5 offset +38mm
Nitto 555
F - 235/35/20
R - 275/35/20
no drop
Pics
Click on picture to enlarge it once opened click picture again to enlarge full size.
![](http://img239.imageshack.us/img239/2962/lexus1aa.th.jpg)
![](http://img147.imageshack.us/img147/8420/lexus18lc.th.jpg)
![](http://img239.imageshack.us/img239/6668/lexus26xm.th.jpg)
![](http://img147.imageshack.us/img147/3637/lexus31ch.th.jpg)
![](http://img239.imageshack.us/img239/7882/lexus44ot.th.jpg)
![](http://img239.imageshack.us/img239/715/lexus50vb.th.jpg)
![](http://img239.imageshack.us/img239/8847/lexus65ie.th.jpg)
IS350
Nitto 555
F - 235/35/20
R - 275/35/20
no drop
When I have two passenger etc on rear seat accompanied with passenger front on well on highway when I get a bump I hear the rear rub again the outer fender (the part that people usually roll) but makes no damage to tire or car its self, you just hear it rub when you get a hard bump.
And in the front when you turn in about 90 degree angle it rubs against front wheel well plastic which i got a heat gun to push the plastic a little bit in to get rid of this problem. I remember another member on the forum with 20" doing it as well.
Originally Posted by tim817
To elliminate the rear rub, i recommend you to change your rear tire to 275/30/20 the next time you replace the tire. It'll be closest to stock diametter. Since the IS350 are RWD, they're using the rear to calculate speedometter. The 275/35/20 diametter are bigger than stock so the speedometter will be inacurate. If your speedometer reads: 65 You're going approximately: 68.87. Here is the link for tire calculator: http://www.discounttire.com/dtcs/infoTireMath.dos
I have 275/30/20 with a higher offset: +43 and never had rear rubbing problem.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![](http://img239.imageshack.us/img239/3675/lexus78fa.th.jpg)
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Is it possible to run 18x9's in the rear with stock tires ? I wanna keep the stock tires and get a set of lightweight wheels with same offsets if possible ? I'm thinking maybe Lexions 203's nice and light.
Lexus IS model: 350
Wheel Make & Model: Volk Racing GT-7 RBC
Wheel Size (diameter and width): 19 x 8.5 F & 19 x 9.5 R
Wheel Offset Front: +36
Wheel Offset Rear: +36
Tire Make and Model: Toyo Proxes T1-R
Tire Size Rear: 275/30/19
Suspension mods: stock
Amount of drop: none
I am very pleased with the wheels & tires. Like I mentioned they dont rub at all and ride is even better than stock. Braking is so much better also. The Toyo T1-R are such a improvement from the T1-S. The ride comfort and noise are all much better.
